Old 03-24-2013, 05:56 PM
Default Re: The New Project: Part Deux!
Sure, if we can manage it in three hours, at the local high school, at night!
[img]<<GRAEMLIN_URL>>/grin.gif[/img]
I am trying my best to get all the underbody stuff done myself, so when it comes time to paint, it is just topside stuff, only.
Old 03-25-2013, 03:02 AM
Is there anyone out there (near me in NJ) who has the equipment to paint the correct spatter paint in my trunk? I dont want to do the spray can method and would much rather get the correct finish done, whether by paying for it or borrowing/renting the equipment.
Old 03-30-2013, 02:26 PM
I finished up the bodywork and prep on the driver's side trunk drop-off. In order to reproduce the original heavy body shutz sound deadener I used a couple cans of spray-on bedliner instead of undercoating. It worked very well as long as you spray it from at least a foot away to allow it to hit the panel in a dryer state. You don't want to spray it on wet. It will look too smooth at a minimum and will all &quot;landslide&quot; off the panel if it is too wet.
Here is the original drop-off from my 1972 Trans Am that was built a week before the Formula at Norwood:
And the finished result:
It's a helluva lot better looking than the way it came:
Old 03-30-2013, 09:04 PM
I got the trunk finished today. I spent a couple hours soaking the plastic tail lamp housings in PurpleStuff degreaser to remove the fossilized remains of that roofing tar/rustproofing that encased them. I also pulled the tail lamp wiring harness out and masked off the trunk area.
I first used some red oxide primer to spray a small area at the inner, tops of both NOS quarters because they were still in their original black E-coat, instead of red oxide dip primer. I then sprayed the areas that were going to get the trunk speckle paint with dark grey sandable primer. This really helped with the speckle paint coverage. I was able to do the entire trunk with one can of the Eastwood Trunk Paint since the background dark grayish color was already there.
To get the right finish I really stood back a ways to get the spray as dry as possible when it landed. I was spraying from outside of the trunk opening most of the time and I used small one-second bursts with the can until I got enough coverage to resemble the original speckle finish that is still remaining in some areas of the trunk, such as the trunk latch bulkhead. I think it came out reasonably well for a spray can job.
Here's the original post pressure washing photo:
And today's results:
Old 03-31-2013, 12:38 PM
70 Forest Green Zee's Avatar
70 Forest Green Zee 70 Forest Green Zee is offline
Steve....that trunk turned out excellent! You are quite a craftsman and I enjoy reading your threads and seeing how you tackle particular areas of your restorations. Keep those pics and this thread going....I'm sure many here feel the same!!!
1970Camaro Z28
Old 03-31-2013, 02:07 PM
Ryan1969Chevelle's Avatar
I agree 100%, keep the pics and commentary coming.
Ryan
Old 03-31-2013, 08:10 PM
Thanks guys!
Sometimes I wonder who is reading this stuff or if I am posting for my own entertainment. [img]<<GRAEMLIN_URL>>/grin.gif[/img] My other thread has over a million-and-a-half views now. It's like it has a life of its own now!
Old 03-31-2013, 08:46 PM
mockingbird812's Avatar
Sharp Mac! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Sam...
Old 03-31-2013, 09:44 PM
I am thoroughly entertained by your threads. I've through about posting similar threads about cleaning original parts but there never seems to be enough time in the day. I am revamping my blasting cabinet in the next month and will try to post results of different types of cleaning that can be done in a media blaster. I have learned a lot from your posts Steve.
Thanks for taking the time,
Old 04-01-2013, 10:57 AM
KevinW KevinW is offline
Steve, that is pretty much exactly how I did mine, but I did the black undercoat, since 69s are black and aqua. Not sure about Eastwoods, but my Duplicolor was still very fragile when completely dry. It would rub off easily. I ended up putting many coats (7) of spray can matte clear to get a good protective coat. Kevin
69 327 convertible (driver)
