Old 03-10-2015, 09:19 PM
67 442 67 442 is offline
I looked in my Product Information Manual and F70-14 Goodyear whitelines are not listed as as a available tire on your car. It's just a guide not written in stone.
Old 03-10-2015, 09:21 PM
The material that is between the tank and the trunk floor is available.
Old 03-10-2015, 10:59 PM
green crv green crv is offline
Hi Ryan, looks like your having fun, enjoying the pictures. Don't forget to save the valve stem caps, may be original DILL. Just found a few old new ones. [img]<<GRAEMLIN_URL>>/[/img]
Old 03-10-2015, 11:08 PM
Ryan1969Chevelle's Avatar
Thanks Phil looking forward to getting the assembly manual.
I will check the caps, DILL? Maybe?
Ryan
Old 03-12-2015, 10:07 PM
Bob_D Bob_D is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan1969Chevelle</div><div class="ubbcode-body">Thanks Phil looking forward to getting the assembly manual.
Ryan </div></div>
One of the pics was clear enough to see the &quot;DILL&quot; Nice!
Old 03-10-2015, 11:21 PM
Looked at some fluids today.
Is the silicone Brake fluid a good idea? I understand it resists soaking in water so seems like a good plan as the car will sit for a good portion of the year.Cost three times as much as Lucas Brake Fluid....must be good:-)
Ryan
Old 03-10-2015, 11:28 PM
Is this the best rear end gear lube? Says it needs no posi additive? Should I add additive to this stuff? Motorcraft or GM?
It also looks to be the right stuff for the Muncie...that would be nice to only keep one on hand:-)
Ryan
Old 03-10-2015, 11:35 PM
Couldn't find my brake tools, got new ones, just cheap stuff, not professional:-)
Old 03-10-2015, 11:58 PM
chevyman0429's Avatar
Ryan
I've been using the exact same brake tools for the last 20 years.
1969 SS 396 chevelle
1978 chevy shortbed step side
1983 chevy shortbed
1985 chevy shortbed
Old 03-11-2015, 12:04 AM
NO, YOU CANNOT MIX OR ADD....SILICONE BRAKE FLUID.....with Regular Brake Fluid.
