Old 04-23-2007, 03:21 PM
Default Re: 72 T/A progess
Where I made the mistake was not the foam insulation around the heater core tubes; I actually got that right. Where I messed up was, there's a foam gasket that is supposed to go around the opening in the firewall ,from the inside, before the heater box is installed. That's how I installed this foam seal, only to find out after everything was all nicely routed and buttoned up, that there were instructions on the flip side of the paper I had been looking at.
Like a dope, I never realized that there were instructions with my heater core seal kit and just reviewed the pictures. It looked like the foam seal went on the firewall (engine side) before the blower motor assembly was installed.
I don't know how much of a big deal that is, I just figured you guys would probably take it apart and do it the right way.
Old 04-25-2007, 04:10 AM
And here is the final pair all finished and awaiting the nose assembly to put it in.
Old 04-27-2007, 01:27 AM
ENOCH sent me a couple more photos today of the block sanding progress. He has both doors done, (including the NOS skin on the driver's door), the hood and the trunklid. These were a couple of the in-process shots. More to come...
Old 04-28-2007, 11:15 PM
I was doing some more finagling around with the car today, cleaning up the headlight buckets. While I was waiting for them to dry off I unbolted the trunk latch. I took some photos for documentation purposes. As you can see the trunk latch was installed when the car went into the giant primer dunk tank back at the Norwood plant in December 1972. You can see the red primer covered with traces of the exterior white overspray as well as the black and turquoise trunk spatter paint over that. It's interesting to see that the undersides of the mounting bolts have the primer on them as well. That e-coating did its job: it got everywhere.
Old 05-01-2007, 04:51 AM
I went to Carlisle a week or so ago and picked up a new gas tank for the car. I have been holding off on ordering one since I didnt feel like paying $50+ in shipping for a $150 part. I bought the tank there and carted it home. My original tank has two large screw holes in the top where someone in the past had drilled through the trunk floor to mount something and went right through the tank. Ouch! Yeah, I could have repaired it and kept it but when it comes to safety items like brakes, brake hoses, fuel lines and gas tanks, I dont play around with my life. Replace them, save the originals for posterity and don't ever worry again.
My original tank still had the factory silkscreened stencil barely visible on the bottom with the 12-20-71 date code on it. I have been scratching my head on how to reproduce it when I stumbled across the website www.inlinetube.com and found that they reproduce the stencil! (go to their website and look under "gas tanks" and you will find it). I had to do some modifications to get my exact date code but in the end it reproduced it exactly.
Here's the original tank with the ghost image of the factory US Steel Stamp still visible (barely):
Old 05-01-2007, 04:54 AM
The stencil is more like a decal with cutouts in it. You clean the tank with lacquer thinner and carefully peel the front off of the decal and place it one the tank. Then use a squeegy and make sure it is firmly attached. You then carefully peel the backing off making sure all the centers of the letters stay on the tank.
Old 05-01-2007, 05:01 AM
The stencil was close but it did not have the cutout for the day, only the month and year. (They accidentally sent me the wrong year "72" instead of "71"). I ended up taking a photo of a ruler next to the decal and printing out the correct scale photo on my printer. I then used an exacto knife and cut out the "20" and the "71" from the photo. I then cut out a spot for the month in the center of the stencil and applied both sets of numbers.
Old 05-01-2007, 05:02 AM
Next, I masked off the tank and sprayed the stencil lightly with several coats of flat black.
The final result duplicated the original tank stencil perfectly.
Old 05-01-2007, 06:48 AM
Looks great Steve. Dedication and attention to detail pays off.
Rick
Old 05-01-2007, 04:06 PM
Here's another bit of useless trivia for everybody. The date on the original gas tank is 12-20-1971. According to the cowl tag, the car was scheduled to be built the first week of December 1971 (12A). It was completed and shipped on 12-21-1971 to Reliable Pontiac in Roseville, California. How's that for "just-in-time" parts delivery at the plant?
