Old 02-21-2016, 06:14 PM
VintageMusclecar's Avatar
Default Re: Gramma's Car: the new project!
What # are you running now?
Old 02-21-2016, 08:17 PM
UR45
Old 02-21-2016, 09:26 PM
UR55 is the next coldest and the only one available with the wide gap. If you're willing to run an .035" gap plug you can go to a UR6.
Old 02-21-2016, 10:45 PM
Since the car runs an HEI it probably needs the wide gap for the plugs.
Old 02-22-2016, 12:33 AM
The reasoning behind the big gaps "back in the day" was to create a bigger flame kernel to try to light off the ultra-lean mixtures they employed back then to get them past the smog sniffer.
I've never had a problem running .035" gaps with an HEI, that's what I'm running with my 357 small block in the Malibu wagon. I don't think you'll have any issues if you're willing to give it a try.
FWIW.
Old 02-22-2016, 12:55 AM
Oh, if that's the case, I do have an extra set of the .040 gapped NGK UR4 and UR4GP which is the factory heat range for the '72 455HO engines. But that might be too hot of a heat range I imagine?
Old 02-22-2016, 02:53 AM
cook_dw's Avatar
cook_dw cook_dw is offline
Congrats on the article.. I've ran NGK's for years and never had any issues.. I even have them in the green car.
Old 02-22-2016, 03:08 AM
With NGK plugs, the higher the number the colder the heat range, i.e. 4 = hot, 5 = middle, 6 = cold.
I *believe* ranges 4,5 and 6 are the standard passenger car heat ranges for NGK's, you might have to upgrade to a premium or race plug to go colder.
FWIW, I was running UR5 plugs in my 496 and they were too hot. I've since switched to 6's which I am still currently evaluating.
Old 02-26-2016, 04:49 AM
JRC99's Avatar
JRC99 JRC99 is offline
Just got my copy of Hemming's! Congrats, man!
My cars, passed down by my grandfather:
'68 Camaro SS (454/TH400, possible L78/M22) LeMans Blue, black deluxe interior, black vinyl top. 3.73- mostly Day 2.
'89 Mustang GT- 3.55, subframe connectors, muffler delete, and a couple other minor mods. Exactly as he wanted it, so how it shall stay
Also:
1995 Ford F-150 XL
2004 Dodge Ram Hemi GTX- #192 of 433
Ain't no fun in viewing your car as an 'investment'. Get out there and beat on it!
Old 02-26-2016, 12:24 PM
Thank you! I just got my extra copies that I purchased, from Hemmings. My subscription copy hasn't showed up yet!
