Old 10-30-2015, 03:41 AM
Stage_2's Avatar
Stage_2 Stage_2 is offline
Default Re: SOLD my 1969 SS396 300 Deluxe Post Sedan
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 69 Post Sedan</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: beater68427</div><div class="ubbcode-body">That's cool being a VAN's car I grew up in Topeka and my dad was a salesman at Van-T, I would be sure that car spent some time around the corner from Vans that's were Caterpillar was/is and we drag raced out front the street use to be solid rubber looked like the burnout box at Lawrence strip. </div></div>
Great story.....I sure wish I could get more history about the car from 1969 to 1977.
Kurt </div></div>
Kurt, Your Chevelle was more than likely beating up on Buicks [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Jeff
Old 10-30-2015, 04:02 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Stage_2</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 69 Post Sedan</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: beater68427</div><div class="ubbcode-body">That's cool being a VAN's car I grew up in Topeka and my dad was a salesman at Van-T, I would be sure that car spent some time around the corner from Vans that's were Caterpillar was/is and we drag raced out front the street use to be solid rubber looked like the burnout box at Lawrence strip. </div></div>
Kurt </div></div>
Kurt, Your Chevelle was more than likely beating up on Buicks [img]<<GRAEMLIN_URL>>/smile.gif[/img] </div></div>
Yeah.....but was it a Bad A$$ Red '70 GS [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
Old 11-01-2015, 02:01 AM
Stage_2's Avatar
Maybe...If it ever decides to quit breaking parts. [img]<<GRAEMLIN_URL>>/cry.gif[/img]
Jeff
Old 11-11-2015, 03:08 PM
miket1 miket1 is offline
Looks like the Chevelle is running good .
69 Z28 Burgandy
Old 11-12-2015, 01:08 AM
69 Post Sedan's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: miket1</div><div class="ubbcode-body">Looks like the Chevelle is running good . </div></div>
Yes it is Mike. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 11-12-2015, 01:13 AM
It`s one of them Cars that ALWAYS RUNS GOOD [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 11-13-2015, 04:02 AM
Kurt, what HP you running, is it highly modified or mostly stock spec. engine.
What gears.
69 Z28 Burgandy
Old 11-13-2015, 11:46 AM
Mike, here's an overview of my build.
It's a fully balanced 402+.040 (410ci), M22W trans and 4.56 gears. Stock cast crank, 3/8&quot; truck/thumb rods, custom Ross pistons, 077 aluminum heads, Comp Cams solid roller camshaft (.640/.647 lift-.236/.242 dur.), Edelbrock TM2R intake and a Holley 950hp.
The motor runs on pump gas as the compression is around 10.4. The horsepower is around 450-475. I'd like to pull it this winter, freshen it up, then run it on the dyno again as Gary Soderberg, my engine builder from SRL Motorsports, has a lot more experience on it then 5 years ago.....we could really spend some time on the dyno and dial the motor in better.
Kurt
Old 10-23-2016, 02:48 AM
I purchased these Ansen Ground Grabber traction bars a few months ago from a member.
I wasn't sure if I was going to use them on but today I decided to at least install them and try them out.
The ride is a little more stiff but that's due to no bushings at either end. I really do like the look.
I will leave them so I have full suspension while on the street and probably will at the strip too as my shocks, air bags and no-hop bars seem to work very well.
Kurt
Old 10-23-2016, 02:51 AM
Ryan1969Chevelle's Avatar
What do these bars accomplish? How do they work?
They look cool:-)
Ryan
