Old 05-30-2019, 06:28 PM
Originally Posted by 69 Post Sedan View Post
Next year........
Next Year? Who’s leg are you pulling?
Not happening
Old 05-31-2019, 03:40 PM
69 Post Sedan's Avatar
Not happening
Putting an LS in the car is taking the easy way out.....lol
The car has ran great for 9 years.....this is just a little hiccup that will be resolved in a couple weeks or less....hopefully..... #crossingfingers
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 06-02-2019, 12:42 AM
So, I had to wait for the correct distributor gear as I ordered exactly what I had on the old distributor, which is the same part number. Well the old distributor has a .491 diameter shaft and the new one is .500. 😡
I actually read the instructions on the wiring and it said to install a 1.6 ohm resistor.....although my old one didn't need one. So I ordered that too and installed it along with the correct distributor gear. It started right up and seems to run good. I need to set the timing tomorrow. “Maybe” take it for a spin too!!!
Kurt
Old 06-02-2019, 02:02 AM
Spoke too soon......still runs like S#*T.........gonna have to take it to a friend’s shop......I’m out of "answers"....
Old 06-14-2019, 03:09 AM
I found my issue with the car running bad......a couple years ago I got a wire hot but didn’t seem to be too bad......well, it was and it finally came back to haunt me. It was the resistor wire that fed the coil.
I had a friend tell me to run a wire directly from my battery to my 1.6 ohm resistor for the new distributor. It fired right up and ran great. So I ordered a new engine wire harness and it arrived yesterday. I will be installing it this weekend.
Kurt
Old 06-14-2019, 03:16 AM
Meanwhile, my new clutch arrived late last week, so I started installing that on Monday.
I thought I’d better replace the pilot bushing since it was 10 years old. So, I tried using this Lisle Pilot Bushing Removal Tool but once it filled the cavity with grease, THAT WAS IT!!! I couldn’t get enough pressure on the grease gun to hydraulically push the bushing out.
I got on YouTube and found out that bread works great......not as messy as grease. So I got my input shaft alignment tool that I bought from Crash at last years MCACN show, pushed bread in the cavity and pounded away....it worked like “sliced bread”.
The Following 2 Users Say Thank You to 69 Post Sedan For This Useful Post:
Damien (06-15-2019), scuncio (06-14-2019)
Old 06-14-2019, 03:29 AM
Here are some pictures of the new Advanced Clutch Technology (ATC) clutch kit. This pressure plate seems heavier than the McLeod and Hays. Maybe because it’s SFI rated where the other two weren’t.....at least I know the Hays wasn’t. The fingers are bent different too......? The organic disc appears solid also.....well built.
I finished installing it yesterday evening. I came home from work today and fired it up.....rowed through the gears a little while the car was still on jack stands. Everything seemed normal but the true test will be when I get it back on the road.
On a side note, the foot pressure is a little heavier than the Hays Street/Strip I had in the car previously......but not much more.
Kurt
The Following User Says Thank You to 69 Post Sedan For This Useful Post:
NorCam (06-15-2019)
Old 06-14-2019, 12:55 PM
big gear head's Avatar
Many people already know this, but for those who don't, if you get a new pilot bushing and a magnet sticks to it, don't use it. Many of the bushings that are being sold today have iron in them. They will wear out quickly and may damage the input shaft.
Freddie
The Following 6 Users Say Thank You to big gear head For This Useful Post:
300deluxeL79 (06-15-2019), 69 Post Sedan (06-15-2019), L78M22Rag (06-14-2019), m22mike (06-14-2019), PeteLeathersac (06-14-2019), ruralrte66 (06-15-2019)
Old 06-14-2019, 04:54 PM
scuncio's Avatar
scuncio scuncio is offline
That is one serious looking clutch. Let us know how it works out for you.
The Following 2 Users Say Thank You to scuncio For This Useful Post:
69 Post Sedan (06-15-2019), m22mike (06-14-2019)
Old 06-14-2019, 07:48 PM
mockingbird812's Avatar
Nice Kurt. You gots to be stoked to drive her!!!
Sam...
