Old 05-05-2008, 06:22 AM
Belair62 Belair62 is offline
Default Re: Christmas in May.....(She left her Purse Out)
2.88 in that car is just what the doctor ordered..
Old 05-05-2008, 07:46 AM
ORIGLS6 ORIGLS6 is offline
You're my hero Ken!
Ditto. Barnhart still ranks #1 but Kwhizz is closing.
WOODEN BOATS?? No room in the current garages, but........................... once I get rid of the house up North...................................
Old 05-06-2008, 07:43 AM
kwhizz kwhizz is online now
Well......Took the Afternoon off and decided to change the trans and see what kind of problems were going to come up.......(Remember, I alway's do everything twice)......Had to change the Clutch Disc (T 10 has Fine Spline) and put everything back together with "No" problems......The Hurst Shifter needed to be tweaked slightly (Had to reverse the Reverse shift Rod to get it to clear the Arms on the Gate assy)......But....The biggest Issue will be in modifying the Back-up light switch Bracket to mount on the trans as the side plate has a different Bolt pattern than the Muncie ..........OOPs!!!......Just as I was typing this Crash called and just happened to have the correct Bracket, just came back from his Transmission "Emporium" with the Bracket (Crashes Garage is Transmission Central).....If you need anything.....He has it......Need to get a Turbo 400 yoke and I'm done......Pretty Simple.......
Ken
Old 05-06-2008, 08:12 AM
Awesome Ken! Crash is close to you...right?
Anxious for the after pics!
How about some in car video with the "purse lady" holding the camera...?
