Old 01-19-2008, 12:54 AM
ORIGLS6 ORIGLS6 is offline
Default Re: Air Cleaner Lid
Still a little glitchy today too.
Old 01-19-2008, 04:59 PM
KevinW KevinW is offline
Does any one have an original lid to get exact measurements from? If mine is the same, I want to have the right verbiage for Ebay.
69 327 convertible (driver)
Old 01-19-2008, 06:37 PM
Zedder's Avatar
Zedder Zedder is offline
Kevin, 1967z28 (Jon) posted the correct dimensions for you in a previous post above.
Mark
Old 01-20-2008, 04:06 AM
Mark, yes I did see that, I was looking for the height, filter dia and distance from filter edge to outside edge measurements.
Old 01-20-2008, 07:25 AM
1967Z28's Avatar
1967Z28 1967Z28 is offline
Kevin,
A friend of mine had a cowl plenum aircleaner without a lid and bought a lid like the one you have and it flat out did not work. Having said that, I will give you the information you are looking for.
Height: 15/16"
Filter diameter: 13 13/16"
Filter edge to outside edge of base: 1 1/8"
Base diameter: 16 1/8"
Lid diameter: 16 13/16"
I hope you and others find that information helpful.
-Jon
Old 01-20-2008, 05:00 PM
firez firez is offline
Once again Jon you are the go to guy on these early Zs. Thanks again.
1968 LOS Rallye Green Z28
Old 01-20-2008, 06:19 PM
Jon, much thanks! Too bad my lid is just a little bit bigger on every measurement looks like I just have a junk lid. Thanks for the help!
Old 01-20-2008, 08:54 PM
1967Z28's Avatar
Glad to be of some help even though it did not result in a match for Hugger 69 Copo's friend. Maybe one of the fiberglass repro lids would work on a temporary basis until an original was found.
-Jon
