Old 11-28-2007, 09:36 PM
L78racer L78racer is offline
Default Re: Engine Oil and Muscle Cars
has anybody tried this stuff?
http://www.zddplus.com/
Old 11-29-2007, 02:47 AM
Quote from JohnZ
The "diesel oils" have also been affected recently. The API-spec "CI-4" diesel oil (which has a very high level of ZDDP) has been around for a long time (Shell Rotella, Mobil Delvac, etc.). However, the new EPA Tier II Bin 5 diesel emission requirements that go into effect next year require the use of catalytic converters and particulate traps, which are "poisoned" by the high level of ZDDP in the CI-4 diesel oil, so there's a NEW diesel oil, API spec "CJ-4", with a much-reduced level of ZDDP, intended for use with the new low-sulfur diesel fuels in the 2008 Tier II-regulated diesel engines.
CI-4 diesel oil offers better protection for sliding elements than the new ZDDP-reduced CJ-4 diesel oil; diesel oil used to be diesel oil, but now there are two DIFFERENT diesel oils.
'69 Z/28
Fathom Green
CRG
Link to the thread his quote came from:
https://www.yenko.net/ubbthreads/showflat...true#Post254979
Howard
Old 11-29-2007, 03:09 AM
Frank, I think there is definitely a market for it at that price. Some education would have to be delivered to help create demand for the product. Not everybody is aware of all the re-formulation going on; Rotella and other diesel formulas used to be "the answer" but now maybe not so much..
-Sam
Old 11-29-2007, 03:38 AM
The whole thing sucks. We're trying to preserve pieces of history here, and the government (in their infinate wizdumb) wants to rid us of everything needed to preserve the past!
Uh-Oh, did I just make a political post?????
Old 11-29-2007, 03:50 AM
Verne,
I think you can rail against the generic government, as long as it isn't personalized with "damned liberals" or "stupid evil Bush".
-Sam
Old 11-29-2007, 07:24 AM
Andy Andy is offline
I too have read that the amount of zinc (sulfated ash) content in oil will go down in diesel oils in the near future. It is unfortunate because Rotella is cheap and readily available. I use Rotella in my 'Cuda now because the 340 was built back in 1980. At the time it was built, had the largest hydraulic flat tappet purple cam available installed, so the big springs are hard on the cam and lifters due to a tight 108 LSA and a lift over .500". I guess that if we have to go back to conventional oils, then a camshaft/engine break-in lubricant will have to be added at every oil change. One of the articles I read recommended this. The author said he had been doing it for years. When I was at a super wal-mart the other day, I noticed an oil forumulated for vehicles made previous to 1988. I believe it was one of their house brands. Does anyone have any info on this oil? It was pretty cheap too.
Andy
1967 Camaro 406 4 speed
1969 C/10 383 5 speed
1969 D300 318 4 speed
1969 Super Bee 383 4 speed
1972 K/5 350 Turbo 350
1972 Duster 340 727
1974 'Cuda 340 4 speed
Old 11-29-2007, 07:31 AM
Gary L Gary L is offline
Hi all. I saw this product being discussed over at another board.
Gary
Lemans Blue/Ivory X33. DZ, M20, manual steering. Only BU code rear end is original.
Old 11-30-2007, 02:09 AM
retengw31 retengw31 is offline
This is precisely the same info I have gleaned as not only do I run Rotella T in all my three Olds W cars, I also have an old Ford PSD with 200k miles and hoping for 500k. It's had a steady diet of Rotella T CI-4 forever. Rule of thumb is if you see anything on there about CJ-4, it's the new lower zinc formulation.
The only way to get that now is in the Synthetic Rotella T which still seems to be in the CI-4 category everywhere around here. That stuff is expensive when you consider 14 quarts every 3000 miles. The small extra cost per year in the muscle cars is no biggee.
Oh yeah, the Citgo diesel oil here at Murrays is still CI-4. I'll park everything before I use anything Citgo. And yup, that's a political statement.
I think a good formulated oil at $4.00 a quart would be great. That's bout what I was paying for the old Rotella T CI-4 and CI-4 Plus.
1966 442- L69 4 speed
1968 Ramrod W31- bought new
1968 442 W30-real thing,but a little different
1975 Delta Royale convertible-
Old 11-30-2007, 02:35 AM
TDW TDW is offline
I agree wholeheartedly with your political statement on Citgo.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 11-30-2007, 04:54 AM
frank23 frank23 is offline
Thanks for all the response. All of it is appreciated. Understandably, consumer education is critical in this endeavor. All the additives on the market currently seem to meet our needs at this time, but my approach is completely different. In these changing times just about every lubricant, as well as gasoline, requires some sort of additive to maintain the similar levels of performance and durability that we expect from our cars. It appears that they are no longer optional, all conceived, in my opinion, to compensate for already inadequate products we all purchase. Some European manufacturers have taken the vintage oil situation to the next level by producing a more than adequate performance and protection oil for both their performance and antique automobiles. It would be simple to buy and market these products in the U.S., but unfortunately, due to the weak dollar, and higher costs of petroleum, doing so would result in a quart price of about $12.00 or more. Through continual discussions with ILC Spectro, a new additive package possibly called "Zincare" (trademark pending), blended with the best available base stock will produce a product that both protects and performs under the most severe of conditions. We all use our vintage cars differently, some for daily use, some for racing, and some strictly for show duty, some stay in long-time storage. Our new product is engineered to address all of these situations with no compromise. Hopefully, the perfect blend can be found soon, so we can continue with testing prior to sale. Thanks for the continued support. Regards -- Frank
