Old 03-09-2007, 09:34 PM
KMOTION KMOTION is offline
Default Re: I need some help with block numbers
Hey Alex,
The 3963512 in my car is dated D219, just about a month before yours. Yes, it is valuable as these date coded 427s were installed in the 69 COPO Camaros and Chevelles and also by the dealers that swapped them in place of the original engines. Also many original engines were blown up and replaced with a CE block under warranty. Being a CE replacement block should not lessen the value. If it had the original VIN numbers stamped on it, the value would significantly increase if you could find the person who owned the matching car, if it the car hadn'y already been crushed. 1969 date coded 427 blocks are always in demand. As mentioned above, you probably have already received a few private messages asking about a possible sale! Good luck. Jim
Old 03-10-2007, 02:01 AM
stomperalexames stomperalexames is offline
No not one yet, but if you guys want I will try to take a pic of the 7 again if need, it looks original to me, and today I also noticed that on the bottom by each cyclinder hole on the oil pan rails it is stamped 7 on most of the holes except the to back I think are stamped number 6???????????? I can do some pics of that to if wanted.....
Old 03-10-2007, 03:29 AM
jerry j jerry j is offline
Hi, The numbers on the pan rail are the cylinder sizes in relation to the piston size, the original fitted pistons had the same # stamped on them as the pan rail.
Jerry
Old 03-10-2007, 06:32 AM
Jerry
Someone told this to me a long time ago. I never verified it though.
Old 03-11-2007, 05:55 PM
DRIVER155 DRIVER155 is offline
Hey , what kinda price range are the 69 427 blocks worth std. bore ? Thanks
Old 03-12-2007, 07:27 AM
I have had a lot of input on this,, I have been told it's worth $10 to $15,000 if it had the numbers stamped on the pad, I lot of guy's also said it is what makes the difference on a $30,000 or $300,000 car????????? I would sell it if somebody is needing a may 23 , 1969 block.......
Old 03-13-2007, 07:06 AM
joey joey is offline
how much? send to [email protected]
