Old 11-12-2006, 04:15 AM
Default Re: L78 VIN stamp photos
Try looking on the drivers side of the trans.,behind the shift linkage protective rubber boot,where the trans. pan meets the trans. body.You should see a recessed machined pad that should have the exact same formated CON VIN as your engine.
Also inspect the bellhousing outer flange for same.
Old 11-12-2006, 04:43 AM
------Is it possible that the 19N is simply stamped deeper rather than larger and therefore look bigger. If you look at the #s as a whole they look like the letters get shallower towards the end of the #s, and therefore look smaller.......Bill S
Old 11-12-2006, 05:07 AM
kwhizz kwhizz is offline
I think he has the '7' highlighted wrong. The top of the '7' is lower than where he highlighted and then that makes the numbers line up pretty good. But it also lookslike that area was sanded down a little in the attempt to read the numbers and that actually made it worse to read.
What do you Expect from a "Middle Age White Guy"......EH!!!!
Ken
Old 11-12-2006, 05:14 AM
Denis Denis is offline
Old 11-12-2006, 06:26 AM
EH!!!
Ken
Old 11-12-2006, 06:41 AM
Zedder's Avatar
Zedder Zedder is offline
I'm glad Jeff noticed the "other" 7 I just couldn't see how a gang holder could let a number float that high above the others. Did you buy the car thinking it was the original motor without a VIN stamp on it?
BTW Denis, I gave your email to a fellow that I know tonight that owns a '69 Z was owned by the same guy that owned your old '67 Z with the "Luv 2" (or whatever it was) plate. He has a pic of his car with the same PA plate on it and would like to speak with the previous owner to get some history on the car.
Mark
Old 11-12-2006, 07:22 AM
I bought the car because I liked the color.
I talked to your friend, gave him the seller's phone #. He's happy.
Old 11-12-2006, 08:12 AM
Zedder's Avatar
Then finding it has the original block is a huge bonus! Thanks for helping Robert out...he's a nice guy
Mark
Old 11-12-2006, 09:18 PM
Jeff, neither ae restamps. I pulled both the engine and trans myself and both have different fonts. I think I may have to contact CRG on this one. I know everyone is thinking, how do you know they are original stampings? They are and I can prove it. Strange....
Tommy Mathison
Old 11-13-2006, 12:38 AM
DarrenX33's Avatar
Lighting is a problem, but here is a "car guys" where's Waldo.
1969 Z28
1972 Corvette
