Old 06-24-2000, 02:36 AM
CopoCrazy CopoCrazy is offline
Default COPO Identification
Hello all. I am fairly new to the COPO world and am interested in purchasing one. I have been involved in restoration of muscle cars for about 6 years, but want to make sure I get my COPO purchase done right. What are some ways to identify a real COPO?
Thank you.
Old 06-25-2000, 06:15 AM
GMH454 GMH454 is offline
Default Re: COPO Identification
Can't help too much technically, but something about let the Buyer Beware keeps coming into mind. Known history helps enormously, as does seller with credibilty.
Chev engines numbers are no guarantee of originality.
Old 06-25-2000, 06:13 PM
COPO COPO is offline
Suggest you start doing some research from the various printed material if you are serious. Since you didn't specify which COPO, I assume you are referring to the most common COPO 9561, ie. a 69 camaro w/iron block 427.
Beyond the obvious engine block numbers here are a few other things to check.
1) Silver grille (common to all non SS cars)
2) Single 3/8" fuel line from gas tank
3) On Norwood built cars X-11 or X-44 on cowl tag. (Having these codes does NOT mean it is a COPO 9561, could be a base car or an SS 350)
4) check for a 4 core radiator (most COPO's had curved neck)
5) Check driver's side outer rear frame rail for welded plate indicating the car came factory equipped w/dual exhaust.
6) most importantly check for "BE" coded rear axle. unique to COPO cars
7) cowl induction hood.
8) power disc brakes.
9) re-read the above post.
That's all that comes to mind. Good Luck!
Old 06-26-2000, 03:40 AM
Horseman Horseman is offline
I also have been looking but just to darn picky. Learned alot from books, but they say don't always believe what you read. Go to the shows. And yes BUYER BEWARE. Good luck
67 Camaro SS/RS 396 4sp
72 Chevy Cheyenne 4x4
Old 06-26-2000, 12:55 PM
The '69 COPO/Yenko Camaros can also be X66 bodies.
Old 07-01-2000, 02:09 AM
To further clarify a bit. The Norwood built COPO 9561 would only be coded X-11 or X-44. The first 50 COPO 9737 (Yenko's) would be coded X-66. The remainder of the Yenko's would be X-11 or X-44.
[Edited by COPO (06-30-2000 at 09:09 PM).]
