Old 10-31-2025, 08:41 PM
1crossram 1crossram is offline
I have had several 67 350 cars and all stopped fine with only drum brakes. Don't let this be a consideration for buying. The trans should be stamped on the top with the VIN, even the early built cars. Usually near the very front of the transmission is where the stamp is found.
1967 Camaro RS/SS convertible Butternut yellow with black power top, factory AC
Rebuilding 1967 RS headlight motors
Old 11-01-2025, 12:55 PM
A question regarding body side moldings on a 67 Camaro. Is there an easy way to tell if they were hung with fasteners or adhesive without removing the door panel? I am curious if there is a visual way to tell by just looking at the type of molding.
Thanks
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS (Sold)
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle (Sold)
Old 11-01-2025, 02:19 PM
Too Many Projects's Avatar
The spear was on all cars and would need the tape to touch the top and bottom edges to hold it. Same with the rs trim pieces. A close look should reveal tape between the trim and body. Those are only trim from the factory. If you are talking about door dig prevention tape down the side, it would have been applied with tape from dealer or owner. I have heard of some having studs that needed holes drilled, but I don't think that was common.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 11-02-2025, 01:29 PM
This is the body side molding I was asking about. Not sure I want this to stay on the car? If it is adhered on hopefully not an issue. If riveted or hung with fasteners a problem for me. Anyway to tell with this photo?
69 Z/28 RS (Sold)
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
