Old 10-25-2025, 08:56 PM
luzl78 luzl78 is offline
That should go 80,000-90,000
Old 10-25-2025, 11:54 PM
1967 4K's Avatar
1967 4K 1967 4K is offline
I hope it does. 👍😋
Richard
1967 Camaro SS 396/375 4K
Old 10-26-2025, 02:04 PM
vette5762 vette5762 is offline
Could you order a QL code 3:31 non-posi with a L 78 ?
67 RS/SS L-78 Convertible
62 Bubble Top 409-409
66 SS Nova L-79
Old 10-26-2025, 02:47 PM
Steve Shauger's Avatar
Administrator
I'm not certain but believe 3:07 the standard ratio if the buyer did not specify a specific ratio.
www.vintagecertification.com
Old 10-26-2025, 06:25 PM
67since67's Avatar
This 323 from a '67 Chevelle was cast F 8 7 and stamped T0630 same as Steve's L78. Any known 323's cast/built earlier than these??
Old 10-26-2025, 06:39 PM
Steve is 4 bolt Chevelle is 2 bolt which means nothing but info.
67since67 (10-26-2025)
  #27
Old 10-26-2025, 10:36 PM
1967 4K's Avatar
Hmmm 🤔, got me thinking about my rear end housing code stuff. I remember Mike S. telling me he got the rear from Bob Harris. The ring n pinion is 3:73.Get back later.
Richard
Old 10-26-2025, 10:46 PM
1967 4K's Avatar
Default QW rear
My rear housing code is QW 06 01 G1.
QW is 3:55 ratio. I know it’s a 3:73 because it had a chrome 12 bolt cover and I put an OEM black one on it. Counted the ring n pinion teeth while I had the cover off.
I’m sure Mike S. would not have bought n installed an incorrect rear for the car.
Richard
Old 10-26-2025, 11:15 PM
He wanted you to go a little bit quicker.
1967 4K (10-27-2025)
  #30
Old 10-27-2025, 06:59 AM
I don't track Camaros, but do track 66-67 L78 Chevelles. I have recorded the following legit 323 block 67 Chevelle L78's:
T0627EG cast ??
T0627EG cast either F57 or F87
T0628EG cast F87
T0630EG cast F87
However, 406's were still in use at the same time. I have recorded many legit 406's with June assembly dates, including several stamped T0627EG (including my 07B Coupe and my 07D ElCamino) and T0628EG.
Steve, was your yellow Chevelle a 323 or a 406? I have it recorded as T0705EX, but didn't have a pic of the casting no.
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
66 Chevelle L78 unrestored
67 Chevelle L78 unrestored
67 Camaro SS350 Survivor
