Old 03-31-2023, 04:09 AM
Originally Posted by scuncio View Post
That’s interesting, I’ll look into it. As long as you’re starting with a dry system, I’ve never had an issue with DOT5, other than bleeding it every 5 years or so on a preventative basis.
I have used Lone Star exclusively for 30+ years, and never a problem. I'm currently restoring a 1969 350/350 A/C Corvette Roadster and a 1976 Corvette Coupe and received exchange Calipers for both projects. Everything looks as it should. The kicker is there was a note inside all calipers that if anything other that Dot 3 brake fluid was used, the warranty is VOID.
Back in the late 1980's all we ever used was Dot 5 silicone brake fluid because it would never stain the paint. But that was then, and this is now. Bill
Old 03-31-2023, 02:20 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Per White Post Warranty statement.
"Lifetime Warranty
We fully guarantee all parts that are sleeved and/or rebuilt by us, with the exception of those used in conjunction with silicone fluid (DOT 5)."
White Post Warranty on Rebuilds
The Following User Says Thank You to cook_dw For This Useful Post:
juliosz (03-31-2023)
  #23
Old 03-31-2023, 02:30 PM
juliosz's Avatar
juliosz juliosz is offline
Does anyone know if DOT 5 fluid actually changed or did the seal material? On Corvette Forum, several folks have reported only Raybestos kits work fine with DOT 5 (no leaks). I spoke with Lonestar the other day as I sent them my calipers. They told me they dropped some seals into a container of DOT 5 and it caused them to degrade after time.
Old 03-31-2023, 02:39 PM
cook_dw's Avatar
Does Lonestar have a website other than facebook? A phone number or anything? If you have to be a wholesaler to deal with them then I wont bother. What price did they quote on bore & sleeve if you can say?
Old 03-31-2023, 06:05 PM
juliosz's Avatar
I can tell you what the cost is after they come back Darryl. My wife works at a Detroit area restoration shop that does a lot of business with Lonestar. They do have a website but I think its been down for quite some time. They do show their business phone number however. http://lonestarcaliper.com/maintenance/
The Following User Says Thank You to juliosz For This Useful Post:
cook_dw (03-31-2023)
  #26
Old 03-31-2023, 07:50 PM
427.060 427.060 is online now
I called Lonestar a couple days ago at the number listed on their site that is under maintenance. They are not wholesale only. They quoted me $220 per caliper with a one week turnaround.
Muskegon is $180 per with a 4 week turnaround.
1968 Beaumont SD396
Old 04-04-2023, 11:01 PM
juliosz's Avatar
Just got the calipers back from Lonestar. Ended up costing $450 which included a $20 “babysitting” fee per caliper which my wife explained is a fee Lonestar charges to folks who want the same calipers back that they sent. Shipping was in that total number as well.
The Following 7 Users Say Thank You to juliosz For This Useful Post:
427.060 (04-04-2023), 67since67 (04-05-2023), 69 Post Sedan (04-05-2023), 69M22Z (04-05-2023), napa68 (04-05-2023), olredalert (04-05-2023), X66 714 (04-05-2023)
  #28
Old 04-05-2023, 12:46 PM
cook_dw's Avatar
Calipers look good. Are those the HD caliper pistons? Also good to know about the O'Reilly fluid. Is there a fluid that they recommend?
Old 04-05-2023, 01:57 PM
Apple Hydraulics worked well for me:
https://www.applehydraulicsonline.com/
They do not seem to have the issue with DOT 5 fluid.
Owned since 1978 - First Car
Old 04-05-2023, 02:39 PM
juliosz's Avatar
I don't know if the pistons are considered HD but they are designed for the insulating disc used on J56. It was a little concerning as they called to say the insulating discs sometimes get cracked or chipped. I was relieved when they arrived un-damaged. Regarding any brake fluid recommendations, I think they just tell you what not to do/use.
cook_dw (04-05-2023)
