Old 03-22-2021, 01:01 PM
TimG TimG is offline
I love these stripe pictures.
Old 03-22-2021, 01:58 PM
7TL34 7TL34 is offline
Nice to see the pics of original '65s with stripes. Mine was repainted in 1976, and I wondered if the stripe was correct at the rear, as I've seen some that don't drop down to the tail light. Looks like mine was done correctly.
Old 03-23-2021, 12:53 PM
Too Many Projects's Avatar
Originally Posted by grantprix View Post
And check out the horrible left front fender-to-door gap as well. Must have been a Friday car.
Grant
These survivor pics are the perfect example of the over restored fit of most restoration jobs. A couple of the pics, even I would have to do a little adjusting on. They send my OCD into overdrive, but I'm working on that.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
grantprix (03-26-2021)
  #24
Old 06-04-2021, 05:54 PM
firstgenaddict's Avatar
Originally Posted by L78M22Rag View Post
The paint touch-ups were done by the elderly original owner... I know they could use a bit of wet sanding and polish.
I found this technique on a youtube video 10 years ago if not more...
After filling the chip etc -
Take a brand new razor blade and bend a slight bow in it...
Then holding it between your thumb and index finger lay your ring finger and pinkie on the surface of the car and lightly drag the razor blade against the raised areas of the replaced paint.
- it takes a little time to carefully shave the overfill and level it - then you can hand polish the spot with some fine cut -
I have found that Trying to use sand paper even with a block results in thinning the paint surrounding the touched up area.
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
The Following 2 Users Say Thank You to firstgenaddict For This Useful Post:
markinnaples (08-18-2021), scuncio (06-04-2021)
  #25
Old 06-04-2021, 10:54 PM
67 442 67 442 is offline
The Following 2 Users Say Thank You to 67 442 For This Useful Post:
60sStuff (06-05-2021), olredalert (06-05-2021)
  #26
Old 06-05-2021, 12:20 AM
60sStuff's Avatar
60sStuff 60sStuff is offline
Thanks for sharing the Factory pinstripes on a 1967 442.
They are opposite of the ‘67 GTO. I never knew that. THANKS !
Chris.
The Following User Says Thank You to 60sStuff For This Useful Post:
olredalert (07-26-2021)
  #27
Old 07-26-2021, 03:32 AM
60sStuff's Avatar
Default 1966 GTO Pinstripe
Unrestored ‘66 in Reef Turquoise with the single Cameo Ivory pinstripe.
The Following 3 Users Say Thank You to 60sStuff For This Useful Post:
markinnaples (08-18-2021), mr.4speed (07-26-2021), olredalert (07-26-2021)
  #28
Old 08-02-2021, 07:11 PM
The hand applied stripes are cool... in that when the striping brush was "reloaded" with paint the stripe was plump and then tapers, the same is found in the pinstripes on original paint from the 1930's.
I rehabbed the Original paint on a one family owned 36 Ford - Black with apple green pinstripes.
Actually had to mix and replace part of the pinstripe across the rear of the car because a tarp and blown and worn it off. I will tell you that the Ford Enamel paint holds up much better than lacquer - check out how nicely the paint came up.
~JAG~
NCRS#65120
The Following 5 Users Say Thank You to firstgenaddict For This Useful Post:
427TJ (08-06-2021), 60sStuff (08-02-2021), 69b5bee (08-02-2021), markinnaples (08-03-2021), PeteLeathersac (08-03-2021)
  #29
Old 08-10-2021, 01:16 AM
tom406 tom406 is offline
I believe this side is mostly original paint on this one-family owned '65 GTO I just looked at. Dad ordered with an automatic so Mom could/would drive too. Teal Turquoise Metallic, built in Fremont with the original window sticker and shipper
The Following 5 Users Say Thank You to tom406 For This Useful Post:
60sStuff (08-10-2021), grantprix (08-10-2021), markinnaples (08-18-2021), olredalert (08-10-2021), PeteLeathersac (08-10-2021)
  #30
Old 08-10-2021, 02:07 AM
60sStuff's Avatar
tom406,
You can definitely see the full tinted glass.
Any other photos?
Are you pursuing this ‘65?
Thanks for sharing!
Chris.
