Old 04-09-2020, 06:35 PM
McCune McCune is offline
Let me know when you find a block drilled with the "D" 3" spacing.
Old 04-09-2020, 06:48 PM
rszmjt rszmjt is offline
Will do.
I know I have a 69 “512” block as well as a “351” 67 435, as well as other rat motor blocks, I don’t think I have any early BB. but I have lots of early SB. I will mock it up and check if the hsg fits with all 3 bolts.
Will add to post at a later date, it may be awhile as I’m staying home lately to flatten the curve with this nasty virus.
I amended my post so it does not confuse any one regarding this.
The Following User Says Thank You to rszmjt For This Useful Post:
McCune (04-10-2020)
  #23
Old 04-09-2020, 07:33 PM
chevyman0429's Avatar
I’ll measure mine shortly!
1969 SS 396 chevelle
1978 chevy shortbed step side
1983 chevy shortbed
1985 chevy shortbed
Old 04-09-2020, 08:31 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Originally Posted by chevyman0429 View Post
Yea that’s the plan however for now I’m gonnna use a high torque mini starter that also uses three bolts with the stud. I am on the hunt for a starter or nose of one with the three holes if anyone has any knowledge of what year and what model had this nose.
3 bolt starters are correct for early 409's and maybe early 60's corvettes I believe...…...google part# 1107233 starters - I'm looking for one now.
Jake Dykstra
Dykstra Motorsports
Old 04-09-2020, 09:22 PM
Yea mine is a early 69 512 block but the starter bolts are 3 1/4” apart!
1983 chevy shortbed
1985 chevy shortbed
The Following User Says Thank You to chevyman0429 For This Useful Post:
McCune (04-10-2020)
  #26
Old 04-09-2020, 10:42 PM
That's the only way I can measure mine.
Z15 SS 454 (04-10-2020)
  #27
Old 04-09-2020, 10:43 PM
I found the starter grinding problem the mounting hole in the block is cracked! Not good as it’s a 69 512 block.
OUCH. That sucks big time.
Old 04-09-2020, 10:55 PM
L_e_e's Avatar
L_e_e L_e_e is offline
https://www.summitracing.com/parts/d...SABEgJUo_D_BwE
The Following User Says Thank You to L_e_e For This Useful Post:
PeteLeathersac (04-09-2020)
  #29
Old 04-09-2020, 11:32 PM
John Brown's Avatar
The three hole bolt to the block snouts were used as early as 1957 on Turboglide equipt cars. Have also seen them also used on 409's.
John Brown
The Following User Says Thank You to John Brown For This Useful Post:
McCune (04-10-2020)
  #30
Old 04-10-2020, 12:03 AM
John Brown's Avatar
I have an 1107687 starter listed as fitting a 59 and 60 348 Turboglide car. Just measured it and it has 2 7/8" center to center bolt pattern. As I recall, my old 57 Chevy block had the same spacing drilled on the bottom of the block. I had to plug one bolt hole and redrill the block to use a later aluminum starter snout when I was lightening things up on my old drag race stock class drag car.
John Brown
McCune (04-10-2020)
