Old 09-02-2019, 05:11 PM
Enoch Enoch is offline
Banned
65 396 L78
67 68 69 427 L88
69 ZL1
Thermostat housing mounting bolts. Excellent restored original pieces. The long but has L8 for its headmarking in the short bold has P. As nice as you're going to find. A $80. (X)
Old 09-02-2019, 05:34 PM
Banned
1970 up PCV valve cover hose and T. Included are two original unrestored olive green clamps one original hose and one original tee with original part number on it. $45. (X)
************SOLD ************
Old 09-02-2019, 05:39 PM
Banned
Small block fuel pump and mounting plate bolts. Restored originals. Two original E head marking fuel pump to block mounting bolts and to anchor head marking fuel pump mounting plate to block mounting bolts. I've included a picture of the difference between a fuel pump mounting plate bolt and a timing cover bolt which most people use in this application and is incorrect. The correct ones are longer to make up for the difference in the thickness of the plate. $35. Three sets available PP FF (x)
Old 09-02-2019, 06:12 PM
Banned
One pair of original Wittek # 2 power steering return hose clamps. They do not reproduce these original clamps with a right stamping. $80 pair. (X)
Old 09-02-2019, 07:02 PM
Banned
Three original Buss fuses. Two white stripe that are 25 amp; $ 15 each.
The pink 4 amp is $20. Very nice original pieces.(X)
