Old 09-12-2025, 09:21 PM
Already answered in the other thread posted by the O.P.:
https://www.yenko.net/forum/showthread.php?t=183338
POP also confirms 6-cylinder car originally.
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
66 Chevelle L78 unrestored
67 Chevelle L78 unrestored
67 Camaro SS350 Survivor
Old 09-25-2025, 11:42 AM
AdamApple AdamApple is offline
Default new purchase 1966 L72 biscayne
hello folks.
i am brand new to this.
i joined because i recently purchased an 1966 L72 biscayne.
im jumping on this thread because i see that the discussion is about a 1966 biscayne L72....i hope thats right.
anyway, there are a few things that i could use help with, so i was wondering if anyone could help me.
first, i'm pretty sure the car is real, based on the vin, cowl tag and numbers from the trans and rear, so i'd like to register it, if not already in the registry (i guess the follow up is whether or not this car shows up already).
second, though i haven't done a deep dive and taken the interior apart to find the build sheet (if it is still there), is there a way to get one?
third, i will be looking for some parts to get it as close to original as possible.
the motor is not the original as it was said to have been blown in '68 and replaced with a chevy crate engine (i'm looking into the dates and numbers on that but at first glance appears to corroborate in that it is a 512 block)
it is missing some interior things like a drivers visor and dome light but what is odd to me is that it doesnt have a factory tach, so not sure what happened there.
also the exhaust manifolds arent correct and it is missing the idler pulley assembly.
id love to start gathering all of these things to maybe bring it back to where it was, so any help with where to go to get them, would be great.
thanks,
adam
The Following 8 Users Say Thank You to AdamApple For This Useful Post:
1967 4K (09-25-2025), cheveslakr (09-26-2025), dykstra (09-25-2025), L_e_e (09-26-2025), olredalert (09-25-2025), orig69ss (09-27-2025), PeteLeathersac (09-25-2025), Tenney (09-25-2025)
  #23
Old 09-25-2025, 02:07 PM
dykstra's Avatar
dykstra dykstra is offline
Very cool! Welcome to the best site on the net.
Dave Dykstra
NCRS#66003
Dykstra Motorsports
The Following 4 Users Say Thank You to dykstra For This Useful Post:
AdamApple (09-25-2025), John (09-29-2025), kwhizz (10-02-2025), PeteLeathersac (09-25-2025)
  #24
Old 09-25-2025, 06:25 PM
Welcome to the site. To answer some of your questions....
1. Unlike the prior poster in this thread 'kenbrogan', your car's VIN indicates it was originally produced with an 8 cylinder engine, so that's a good start.
2. Rear axle and trans pictures you have posted have good assembly dates that line up with your car's scheduled production date (from the Trim Tag) of 07A (first week of July). The EJ code on the rear axle indicates it was originally equipped with a 4.88 positraction differential, and had metallic brakes....both very strong indications of a car ordered with drag racing in mind. I believe the transmission should have a partial VIN stamping also, but it could be up on the top of the transmission where it would be extremely difficult to see with the trans still in the car.
3. Unfortunately, if there's no build sheet in your car now, there's no way to get one.
4. Not at all unusual to have no factory tach, as anyone who was going to be doing serious racing would install their own aftermarket tach....the factory pieces were never known for being perfectly accurate, and often were located out of easy viewing.
Can't help with your missing/incorrect pieces but others here might have some ideas.
Bill Pritchard
The Following 9 Users Say Thank You to Bill Pritchard For This Useful Post:
1967 4K (09-25-2025), Arrowsmith (09-25-2025), dykstra (09-25-2025), John (09-29-2025), olredalert (09-25-2025), PeteLeathersac (09-26-2025), RALLY (09-26-2025), Tenney (09-26-2025), Xplantdad (09-25-2025)
  #25
Old 09-26-2025, 12:58 AM
thank you for your insight.
i was thinking the same thing about the tach, being a drag racer myself.
i am looking forward to finding the missing pieces.
much appreciated.
Adam
1966 L72 Biscayne
1970 CST 10 400
1979 Malibu 468 small tire
The Following User Says Thank You to AdamApple For This Useful Post:
Bill Pritchard (09-26-2025)
  #26
Old 09-26-2025, 04:20 AM
.......also a q code in group 2 on the trim tag, so it's a 4 speed from factory. Some say that indicates a M21, but not positive if that's conclusive. Love the car!!
Old 09-26-2025, 09:26 AM
when i did my research before i purchased, i thought the same.
the 2Q means an M21 and the fact that the rear gear is more than 3:31 (in this case 4:88) meant that it can only be a real L72 because you couldn't get that gear otherwise.
4 core radiator, no power anything...
of course, all of that could be faked but like Bill Prichard said, the date codes on the motor and trans seem right....
thanks!
Adam
1966 L72 Biscayne
1970 CST 10 400
Old 09-26-2025, 01:03 PM
That would be trans and rear axle....
Bill Pritchard
Old 09-26-2025, 02:55 PM
fsc66 fsc66 is offline
Default L72
Hard to see but looks like it does have a tach. When you ordered a 4-spd with 325, 390 or 425 HP engine it included the tachometer. If so is the tack a 7K tach with a 6K red line?
Also as stated, he M21 was available only with the L72 motor. Also the 4.10 through 4.88 rear axle ratios were only available with the L72
Paul
[email protected]
The Following User Says Thank You to fsc66 For This Useful Post:
  #30
Old 09-27-2025, 09:01 AM
Sorry Bill Pritchard, you're right, my mistake.
Paul, i heard it both ways, that it came automatically, or you could option the tach, but in this case, it is a clock.
and i also thought the M21 was only available with the L72 as well as the rear gear upgrade, of which i have both and the 2Q code backs that up
Adam
1966 L72 Biscayne
1970 CST 10 400
PeteLeathersac (09-27-2025)
