Old 08-22-2016, 04:13 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Default Re: Enclosed car haulers?
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Crush</div><div class="ubbcode-body">Dave
Did you order your trailer or buy from inventory? What dealer and would you recommend? </div></div>
I bought from inventory. I was going to buy a relatively inexpensive one from KY I think it was. I stopped in to a dealer and told him to &quot;talk me out of it.&quot; He did. I paid slightly more and got 10x the trailer. I went through a dealer in Leominster, Mass. as that wasn't far from me at the time. Airport Trailer Sales. Very good to deal with, but depending on where you are, I'm sure there is something not too far from you.
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
Old 08-22-2016, 04:33 PM
Dave, We stay at my in-laws in Eastern KY for a couple months and then head to Pgh for a few weeks in the summer every year. Up 75 and then across 62 is just the easiest route from SW FL.
John 10:30
Old 08-22-2016, 04:49 PM
Just a note on trailer sway: If the trailer is offered with a spread axle design, I'd recommend it. That doesn't mean it's wider; it means the axles are further apart front to back. That means you don't have such a pivot point in the middle. A little extra tire scrub on tight corners though.
Old 08-22-2016, 05:01 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Jonesy</div><div class="ubbcode-body">Nice trailers! I never knew the Trailer Aid ramp existing or you could do something like that until now.
Im going to have to get one of those. Thanks for the info. [img]<<GRAEMLIN_URL>>/youguysrock.gif[/img] </div></div>
I hate to say it, but buy it from Wallmart for half the price the trailer outfitters charge. It comes with the bracket.
Old 08-22-2016, 06:30 PM
Tommy Nolen Tommy Nolen is offline
I bought mine from the local trailer dealer, that was several years ago, I think it cost about 35 dollars but it didn't come with bracket.
Tommy's Toy
1959 Pontiac Catalina 420a / 3 speed manual
1960 Pontiac Ventura 4 speed
1961 Pontiac Catalina 4 speed
1961 Pontiac Ventura 425a / 4 speed
1962 Chevrolet Corvette
1963 Pontiac Catalina 421/4 speed
1964 Pontiac Catalina 2+2 tri power/4 speed
Old 08-22-2016, 08:57 PM
Donnie's Avatar
Donnie Donnie is offline
<span style="font-weight: bold">Heres my Wellscargo 24' wide body with 5000 lbs. axles</span>
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 08-22-2016, 09:02 PM
Crush Crush is offline
Donnie, is that aluminum? Does the air deflector make a difference in gas mileage? I'm considering a V-nose and have heard pros/cons on such.
Old 08-22-2016, 09:10 PM
Donnie's Avatar
no its not Aluminum.
fuel mileage is a little better then my old flat nose Wellscargo. and the push and pull when you pass a Big truck isnt as bad.
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 08-22-2016, 11:08 PM
Trailers....interesting subject. In my opinion there are 3 different levels of trailers. #1 The low level or cheaper trailers mostly made in Ga., #2, the middle trailers like the Haulmark, Wells Cargo etc. and then #3 the high end trailers like the ATC, Intech like Verne has and some other brands in the high end catagory.
I have 2 trailers, one is a Ga. built trailer (I wouldn't recommend buying one of these) my Ga. built trailer is a 36' gooseneck. I bought it in 2007 and its still in service so it wasn't too shabby. It cost 5k less than a Haulmark so I guess you get what you pay for. The downside was extremely poor workmanship plus the economy in 2008 put them under so I was never able to buy any replacement parts.
The other trailer that I have I just purchased last year, it's a 28' Haulmark. Did you know that Haulmark, Wells Cargo, Exiss, Featherlite, Sooner and probably others are all made by the same company? Universal Trailers. I don't know if thats good or bad, just a sign of the times. In talking to Verne when he was ordering his he was telling me how he spec'd it out, when I ordered my Haulmark last year I told the dealer where I wanted my escape door, his response was &quot;they know where to put the door, don't you worry bout it&quot;. The damn door is close but a good 6&quot; from where I would like it to be. Same on the tie downs, I told them where to put the tie downs but they didn't do it so I had to install my own. I would order another Haulmark but this time they would put stuff where I said put it or I would go elsewhere. I previously had a 2005 Haulmark, the workmanship was much better in it than my new one.
I've never had any experience with the high end trailers although I have friends who have them and for the most part they are happy. The one thing I think they all have in common is tires, they all put junk tires on the trailers. I think even Verne told me that he didn't have a choise in tires. My advise to anyone buying a trailer or spec'ing out a trailer is to go with 16&quot; tires. This creates a problem with the escape door because it requires a larger wheel box but to my knowledge there is not a single 15&quot; trailer tire made in America. The Goodyear Matharon was in my opinion the best there was but they are now made in China. My trailers have 16&quot; tires, I run Goodyear G614 tires, they are made in America and they cost over 300 dollars each but if one of those tires blow out its gonna destroy the fender and most likely do damage to side of the trailer. I replace the tires every 4 years, regardless of tread wear or appearance.
As for a tow truck, get something big enough to handle the trailer. Most of my travels are fairly long hauls. My trucks are a F450 diesel, dually and a F350 diesel SRW. I have used a half ton truck but I believe those using half ton trucks, Explorers and other vehicles of that nature are on a path to transmission failure. My little half ton was a Chevy Silverado SS, it had plenty of power, good brakes and the trailer felt stable but the transmission was constantly shifting gears. The other reason for having a diesel, in my opinion is how far I can go on a tank of fuel, it isn't always easy to get in and out of the filling stations, with a gas vehicle you will need to stop every couple of hundred miles. My trucks will run all day without stopping for fuel. The F450 carries 132 gallons and the F350 holds 87 gallons
Just my thoughts, the other thing that I will add (hope I don't step on any toes) I bought my first enclosed trailer over 20 years ago, never had an aluminum framed trailer, don't want one. I think aluminum frames will tend to develop stress cracks down the road, I have heard of guys getting stopped by the DOT and they were checking for frame cracks
Tommy's Toy
Old 08-22-2016, 11:41 PM
Those are all good comments Tommy. As far as specing everything, inTech sent me a form to fill out that asked for many measurements from my car. They used that to determine exactly where the car would sit in the trailer, then placed the escape door and the tie downs perfectly. Now I could load a smaller car and have the freedom to place it where ever it needed to be in order to use the side door.
They draw up blueprint plans and email them. I checked all the measurements, made a few changes, reviewed more plans then finally signed off. I knew exactly what I was getting.
