Old 07-29-2016, 12:01 PM
JRSully JRSully is offline
Default Re: 1970 Nova rear sway bar ?
FWIW, If your hunting this complete set up, always check the build date, As Marlin stated, they only appeared in the 2nd half of the 70 model year. Anything built prior to Jan 70 would probably not have the set up factory installed. Also, if you find a potential car that has it/had it but the bar and links are gone, check for the floor welded upper mounting brackets anyway. If the car was cut up (raced.?) it was almost certain the bar was in the way and chucked, but rarely would the welded brackets be removed. Grab those anyway
71 Porsche 911 Targa
Old 07-29-2016, 02:22 PM
Agree with Sully, the floor brackets were rarely removed but the sway bar was simply in the way for even installing generic traction bars! The only bars I've seen where the RSB was retained were the Drag Dimension bars, specifically on the Roof Deuce.
Old 08-01-2016, 07:23 PM
Zman1969 Zman1969 is offline
Measured my nova bar was 9/16" diameter. Anyone else have different diameter than that on Nova?
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 08-02-2016, 01:34 AM
NOVAJET NOVAJET is offline
I believe most are 5/8" although I have a L78 car that has a 13/16" rear bar on it.
Old 08-02-2016, 07:29 AM
SSRS SSRS is offline
Hello.I have a complete mint concours 1970 nova SS F41 set-up on Ebay.#322213746086 to see photos.Vic
Old 08-02-2016, 11:23 AM
John Brown's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SSRS</div><div class="ubbcode-body">Hello.I have a complete mint concours 1970 nova SS F41 set-up on Ebay.#322213746086 to see photos.Vic </div></div>
http://www.ebay.com/itm/1970-Nova-SS-Rea...0EA&amp;vxp=mtr
John Brown
Old 08-02-2016, 11:35 PM
Should be 5/8's in dia. !!
Old 08-03-2016, 12:55 AM
The plates are not assembly line correct on that Ebay set up, but could probably cut them to make a correct look
Old 08-03-2016, 04:58 AM
al8apex al8apex is offline
previous offerings ... reserve not met ...
previous ebay offering
one before that
<a href="http://www.ebay.com/itm/1970-Nova-SS-Rear-Sway-Bar-F41-/322180520970?hash=item4b03749c0a%3Ag%3AG-sAAOSwzJ5Xa0EA&amp;nma=true&amp;si=m7wF6x9BhEDXhFJ fIgMqn1sVGog%253D&amp;orig_cvip=true&amp;rt=nc&amp ;_trksid=p2047675.l2557" rel="nofollow" target="_blank">and the time before
that</a>
Old 08-03-2016, 05:42 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: JRSully</div><div class="ubbcode-body">The plates are not assembly line correct on that Ebay set up, but could probably cut them to make a correct look </div></div>
X2
Also, the plates are LH and RH specific....
