Old 06-14-2016, 01:22 AM
Alss's Avatar
Alss Alss is offline
Default Re: 70 W 30 rebuild
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 83hurstguy</div><div class="ubbcode-body">The challenge of the roller cam in an Olds is the 5/16&quot; rocker arm bolts. There are two basic options... the first is drilling the expensive/rare heads for a 3/8&quot; or 7/16&quot; stud and adding guide plates. Option 2 is the Harland Sharp 5/16&quot; bolt-on mini-shaft rockers, which are around $450, and good to 350 lbs open spring pressure.
With roller rockers, you'll have to modify/remove the stock valve cover baffles or double up gaskets. Ram Air Restoration makes a 0.200&quot; thick hard rubber gasket that's a nice piece. The stud mount rockers may clear with a short poly lock, but the mini-shaft ones hit the baffles at max. valve lift... went through figuring that out on my old '83 the hard way.
No doubt a roller is the way to go, other than those pesky Pure Stock rules. I'm stuck with the flat tappet for mine. </div></div>
thanks for the info..speaking with the builder...stay tuned... [img]<<GRAEMLIN_URL>>/smile.gif[/img]
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 07-06-2016, 12:49 AM
Alss's Avatar
OK guys got the rockers figured..cam figured..heads done..thats the good news..bad news..crank cracked..failed mag. rod small ends are oversized..almost can push the pins out by hand!. So, my motor guy found me another shortblock and I'm starting over. [img]<<GRAEMLIN_URL>>/frown.gif[/img] yay.........
Old 07-06-2016, 01:01 AM
Ryan1969Chevelle's Avatar
Oh my goodness......
Better sell some Christmas trees!!!!
That sucks!!!! Why a new block?
Ryan
Old 07-06-2016, 01:09 AM
Alss's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan1969Chevelle</div><div class="ubbcode-body">Oh my goodness......
Ryan </div></div>
only have to go 030 overbore...not happy with 060!
Old 07-06-2016, 03:05 AM
junior supercar junior supercar is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: DW31S</div><div class="ubbcode-body">I went with Diamond forged in my SBO.</div></div>
Dave, you must have bought those a while ago as I've heard from more than one person Diamond quality control has really gone down hill lately.
I'd suggest CP's and BTR in NY has a nice deal.
1969 Cutlass S W-31 - 13.86@100 TnT US41 2009
1970 Tempest GT-37 400ci 4bbl 4sp - [email protected] PSMCDR 2011
1970 F-85 - daily driver or clock it with a sun dial
plus others
So sorry....oh just throw in a ZL-1 in that Olds Post Sedan....it will fit the rest of your stable [img]<<GRAEMLIN_URL>>/headbang.gif[/img]
Old 07-06-2016, 03:07 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan1969Chevelle</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Stefano</div><div class="ubbcode-body">Dick Miller racing has a modified timing chain cover, looks stock when installed as its a stock one cut in 1/2, just in case you want to make cam swaps easier.
</div></div>
Works for small blocks?
As far as I have researched this should be true:-) I want one!!
Ryan </div></div>
For changing out that illegal &quot;Pure Stock&quot; cam [img]<<GRAEMLIN_URL>>/dunno.gif[/img] [img]<<GRAEMLIN_URL>>/grin.gif[/img]
plus others
Old 07-07-2016, 12:20 PM
Alss's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: junior supercar</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: DW31S</div><div class="ubbcode-body">I went with Diamond forged in my SBO.</div></div>
I'd suggest CP's and BTR in NY has a nice deal. </div></div>
going with CP's
I could Dan...but I'll stick with this olds motor I'm building, besides I need the spare for my Beaumont!! [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Old 07-09-2016, 12:25 AM
VintageMusclecar's Avatar
Albert's carb before/after:
We were originally hoping to do a basic rebuild, but when I found the self-tapping inlet fitting (with no filter) and the corrosion &amp; debris inside the bowl (4th and 5th pics) it became a restoration since the bowl would have to be media blasted to address the corrosion.
Just another day on the job.
Thanks again Albert for letting me be a part of your build.
Old 07-09-2016, 01:55 AM
Eric...looks great as always!!
