Old 02-09-2016, 05:00 PM
firstgenaddict's Avatar
Default Re: Nice survivor daytona yellow camaro L78
Here is a pretty good one showing Bill's tail panel
FWIW I used catalyzed black enamel with 50% clear coat added, then 25% flattener by volume.
If you polish it at all it gets glossier.
30% flattener then polished half with rubbing compound and fine polish.
20% Flattener then polished half compound and fine polish.
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 02-11-2016, 07:31 PM
black69 black69 is offline
If you want to get picky, make sure it does not match the standard shade of black body paint. Its a bit different. In the direct sun it acts different than the original black body paint that stays deep black.
Old 02-12-2016, 04:13 PM
It is slightly gray compared to the black on the remainder of the car- if that makes sense.
FWIW Flattener uses fine talc to knock down the sheen- talc is white, which adds an ever so slight gray tint to the paint.
~JAG~
NCRS#65120
Old 02-12-2016, 05:22 PM
That sounds promising you got it right!
Old 02-12-2016, 05:42 PM
427TJ's Avatar
427TJ 427TJ is offline
The Technical and Restoration forum probably deserves a sticky thread on the correct sheen of big-block car black tail panels.
