Made one of the dumbest purchases of my life. The "heavy load" I was referring to was an old Hunter aligment lift. It wasn't the model I was thinking of when I put in a low ball bid. Sucker must weigh 5000 pounds. My trailer weighs almost 2k. So, my twin 3500 pound axles were at the max. On top of that, the load was not centered very well on the trailer, so had too much tongue weight, and only 90 psi in the air shocks.
Good news is the El Camino performed flawlessly on the 300 mile trip. I honestly think this little El Camino could haul a 9k load without issue with the tongue weight about 600 lbs and 180 or so in the shocks. Rock steady at 65 mph all the way home even with the 40 mph cross winds. I think all the mods helped (boxed lower control arms in the rear, bigger sway bars, front and rear, frame stiffeners as used on the later big block cars, and boxing the rear of the frame rails). Had to get up at 5 a.m. and get it hauled back in time for a 1 pm appoinment yesterday. Real fun loading in the cold rain with 40 mph wind. You would think I would be old enough to learn by now. Checked the oil level on the way home and it hadn't moved even a hair off the full mark. Towing is a great test to see if your rings seated. This is my first highway adventure since the engine build. Only complaint is the fuel pump. I will start another thread on that issue.
Took another road trip in the El Camino. First one since changing out the mechanical fuel pump for an electric.
Drove to a small town in Kansas to pick up a complete 3.31 12 bolt rear end. Not worried about numbers matching on this vehicle, but it is even dated correctly for my car. Probably don't need the upgrade from the 10 bolt, but may tow heavy loads from time to time, and will appreciate the peace of mind. Besides, I have some 11 inch backing plates, and plan to change out the rear brakes to 11 inch drums from a full size Chevy to match up better with my Cheap Big Brake upgrade that I already did on the front using modified original drum brake spindles, modified 69 and up brake caliper mounting brackets, Corvette rotors, Chevy truck calipers and pads. Not sure if I posted the link on that, but just in case I didn't: http://www.camaros.net/forums/16-bra...e-upgrade.html I can gather parts and get the 12 bolt all done and ready to install. That way the car won't be "down" while I am doing the brake conversion. Drove about 550 miles all together. Driving mostly 70 mph, achieved and overall mileage of 23.5 mpg. Better than I expected in an open bed carbed El Camino that is about as aerodynamic as a shoe box. Specs Engine: 350, .020 over, flat top pistons, decked block to achieve about .036 quench, 186 heads, with 1.94 valves and very little work. I don't remember the final number, but static cr is around 10.2. Crane hydraulic roller cam that makes torque starting at 1500 rpm (thanks Eric, for the cam) stock 68 Q-jet rebuilt by me on a stock 68 cast iron intake, and jetted down one size on the primaries. Has a cheapo Accell HEI distributor (came with the vehicle... uses stock GM coil, pick up and module) which I dialed in on my Sun distributor machine. 10 degrees initial, 36 total of mechanical and initial, all in by 3200 rpm, with an additional 10 to 12 degrees of vac, hooked to manifold vac. Normally use 89 octane. It will run on 87 without pinging if not pulling a load. So far, have been able to get 100% gas. Not sure how it would run on the ethanol stuff, and would rather not find out. Fuel pump, carb and lines are all supposed to be ethanol compliant. Trans: 4l60E with a stand alone controller (.0696 OD, and converter programmed to lock up after 52 mph). Rear: 3.36 10 bolt rear spinning 275 60 BFG tires on 10 inch vintage Centerlines. Puts my rpm at 70 mph at 1973, right in the torque curve, which is why the good mileage. The 3.31 will only bring that down to 1939 rpm. Maybe I will speed up two mph just to keep it in the sweet spot. Anyone need a complete, drum to drum 3.36 10 bolt out of a 68 El Camino? Would fit other A body cars as well, I believe from 68 - 72.
Don't believe everything you read on the internet ... Ben Franklin Last edited by Lynn; 05-08-2017 at 03:00 PM. |
| The Following User Says Thank You to Lynn For This Useful Post: | ||
VintageMusclecar (05-11-2017) | ||
Lynn, neat project I would love a 69 Elky maybe Tibor can put one of those bellybutton LSA's in there fer ya that would really haul then!
69 RS/Z 302 VE3 Daytona 69 Chevelle SS 396 375 69 T/A clone LS6/6 speed 90 Formula 350 |
Lynn,
I thought all El Caminos came with 12 bolt rears. No??? Verne |
Nope. 307 PG El Caminos got the 10 bolt in 68.
So I guess the 12 bolt in my '69 350/300 is correct?
Verne |
Yup.
Hi Lynn,
Love the truck, you are doing a great job making it reliable and perfect for towing:-) Ryan
1969 Beaumont 350 Auto White Sold 1969 Beaumont 307 Auto Green Sold 1969 Chevelle SS 396-L35 Auto Blue Sold 1969 Oldsmobile Cutlass 'S' Sports Coupe W31 |
Thanks Ryan. Hope you and your son are still having fun with the Olds. I check your thread from time to time.
Keep an eye on my thread, let me know if you have ideas or see me heading in the wrong direction!! Ryan
