Old 01-24-2015, 05:10 PM
427TJ's Avatar
427TJ 427TJ is offline
Default Re: 1967 L35 SMOG question
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Kurt S</div><div class="ubbcode-body">Time to study some parts books.... </div></div>
Oh good! Kurt's on the case!
Old 01-24-2015, 05:48 PM
427TJ's Avatar
My buddy snapped some iPhone pics. I lightened them up a little to reveal more detail.
Two elbows in the air cleaner base, one to the valve cover and the other to the center hose from the back of the smog pump. Open element CA-smog air cleaner bases have two elbows as well:
Gray plastic doohickey was installed 35 years ago when original car, the Impala, was smogged for annual tags:
Power steering pump unbolted:
Back of smog pump:
Old 01-24-2015, 06:54 PM
427TJ's Avatar
Brackets:
Old 01-24-2015, 07:13 PM
427TJ's Avatar
What could this bracket be for?
Old 01-24-2015, 07:41 PM
427TJ's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: travlnz28</div><div class="ubbcode-body">Here's my California Camaro
</div></div>
I notice different pump mounting bracket, maybe different pump with only one hose connection on the back that goes to the air cleaner base, pass side AIR hose routes under pump and seems to connect to driver side AIR assembly.
Old 01-24-2015, 07:42 PM
Kurt S Kurt S is offline
It looks to have the correct RH valve cover.
http://www.camaros.org/engine.shtml#bbcover
Kurt S - CRG
Old 01-24-2015, 10:23 PM
427TJ's Avatar
Yes, it has that cradle bracket for the smog hose (that goes to the back of the carb) to rest on.
Old 01-24-2015, 10:47 PM
427TJ's Avatar
Choke and behind the carb:
Yeah, it isn't L78 or L72 cool but I'm digging it.
Old 01-24-2015, 11:55 PM
427TJ's Avatar
Another friend of mine shot this '67 RS/SS L35 at a show last summer. Looks like travlnz28's '67 setup. Maybe they are different between Camaros and Impalas?
This guy's setup is way out from the valve covers. Pass side hose seems to route to the bottom of the pump. Driver side hose routes to pump but I can't tell how it connects.
Old 01-25-2015, 12:13 AM
Tarrytown SS427s Tarrytown SS427s is offline
Thanks for the excellent pictures! Looks like it was from a South Gate car, and whomever stamped the vin wasn't concerned with going over the N on the suffix! I'll take a look through my library of pictures and see if between that and parts books we can figure out if the Camaros and Impalas shared any of the smog stuff.
Steve
68 Caprice Estate
68 Camaro SS396 4 speed
