Old 02-03-2014, 09:59 PM
GaryC's Avatar
GaryC GaryC is offline
Default Re: Derusting a flywheel.
I googled 10105117 head gasket and found some really good info on this composite gasket. I think I may have what I need there. I believe the quench will be where it needs to be and definitely under .050.
Gary
Old 02-03-2014, 10:46 PM
go for it!
Old 02-07-2014, 11:33 PM
resto4u resto4u is offline
If it has heat cracking, you do not want to reuse. It completely changes the molecular structure of the steel.
Old 02-08-2014, 12:15 AM
GaryC's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: resto4u</div><div class="ubbcode-body">If it has heat cracking, you do not want to reuse. It completely changes the molecular structure of the steel. </div></div>
Don't know how much of that is true but I have seen some sad looking flywheels in my day resurfaced with no problems. Maybe for a street car it would be fine but I think in a race engine it may be questionable.
Gary
Old 02-08-2014, 12:56 AM
yes heat cracking comes back. have to resurface as deep as possible to cut some of that out. I never had a problem with resurfaced flywheels.
Old 02-08-2014, 01:55 AM
GaryC's Avatar
I haven't looked at the flywheel in about a year and to be honest I don't think it was very bad at all if I can remember. It's just covered with that typical rust look when something sits out in the humid air. I don't even think it has ever been cut before. How would anybody tell if it has ever been touched?
Gary
