Old 02-09-2012, 12:26 AM
Big Squeeze Big Squeeze is offline
Default Re: How to ID 1968 SS or Z28 camaro??
OK.......just got out from under the car.......The rearend is stamped "BL 0524G1" .......I couldn't get a good pic of it since the exhaust runs right in front of it......So, BL means 3.07 gears in a 12 Bolt and Non posi traction....."05" means it was built in May......."24" means it was built on the 24th day of May......and "G1" means it was built at Detroit Gear and Axle on the 1st shift.......
The transmission is stamped P8 then "H" and then it looks like "95"......but the "5" is very difficult to make out......"P8" means 4-speed Muncie and it's a '68 model.......the "H" means it was built in June.......and I'm not sure on the "95".......It appears I'm missing a digit.......I'll go back out and try to read it again.....
and the driver's side trunk torsion bar is larger than the passenger side bar....... [img]<<GRAEMLIN_URL>>/beers.gif[/img]
Pump gas and hydraulic cams are for minivans....
Old 02-09-2012, 01:07 PM
68l30's Avatar
68l30 68l30 is offline
Here's your color and stripe, minus the black top. Nice car, good luck with it!!
Big
Old 02-09-2012, 02:55 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 68l30</div><div class="ubbcode-body">Here's your color and stripe, minus the black top. Nice car, good luck with it!!
Big
</div></div>
That does look AWESOME!!! but I found out that this car was originally gold instead of green......I'd seen color under the door panels but it was barely dusted on and in my dimly lit shop it looked green to me......
It that an original SS?? This car has &quot;SS&quot; on the front fenders under &quot;Camaro&quot;.......is that correct??
Old 02-10-2012, 01:06 PM
68l30's Avatar
That is the correct 68 G code color. It's called Ash Gold. It is a very light sensitive color that flips between a olive green to a very light gold depending on the daylight.Her is a different angle and light.
My car is the base model with the stripe added as a RPO.
Big
Old 02-10-2012, 02:51 PM
That's such a cool car big Steve!
Old 02-10-2012, 03:12 PM
68l30's Avatar
Thanks buddy!!
One of these days I'll get you a write up on it....LOL
Old 02-10-2012, 09:32 PM
Looking forward to it!
Old 02-11-2012, 07:08 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 68l30</div><div class="ubbcode-body">That is the correct 68 G code color. It's called Ash Gold. It is a very light sensitive color that flips between a olive green to a very light gold depending on the daylight.Her is a different angle and light.
Big </div></div>
Wow, that does look nice!!!
