Old 01-30-2012, 11:09 PM
dl7265 dl7265 is offline
Default Re: Radiator tank codes
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Donnie</div><div class="ubbcode-body">can anyone tell me what these tanks are for?
IA
CF </div></div>
Buick should have a SJ metal tag.
DL
1969 Buick GS Stage 1
1970 GS455 Stage 1 4-speed
Old 01-30-2012, 11:19 PM
Woj's Avatar
Woj Woj is offline
Donnie,
The reason I said the code is BJ, is that is what is listed on this build sheet for a 69 Chevelle L78 with auto trans. See below:
This is a known low mile original survivor car. I deleted the VIN intentionally. The car is real with less than 5K on the odometer.
This is the second L78 auto 69 Chevelle with the BJ rad code that I know of. I can't guarantee the radiator tank codes at this point. What I mentioned earlier was based on the ebay auction for that tag. I know the IA tank code is good, not 100% on the trans cooler side of the rad. Jim, do you have a 3 core 69 BB auto trans rad to shed some light on the tank codes?
Phil Woj
Old 01-31-2012, 08:00 AM
Kurt S Kurt S is offline
If I'm reading the date right, that's a later 69 L78. So probably a running change.
Interesting. I've seen a BJ tag with IA and XI tanks and 16 core code.
At least the second time I've seen conflicting tags.
Kurt S - CRG
Old 01-31-2012, 03:15 PM
Phil,
Nicely optioned L78 [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 02-04-2012, 05:05 AM
Woj's Avatar
Woj Woj is offline
In the for-what-it-is-worth-file, a friend of mine's 69 Chevelle, L78/automatic built in January of 1969 also had the &quot;BJ&quot; radiator code on his build sheet.
Phil Woj
Old 02-05-2012, 03:56 AM
Donnie's Avatar
Donnie Donnie is offline
Thanks Phil.
so, it looks like it could be either or.
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 02-06-2012, 12:17 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: dl7265</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Donnie</div><div class="ubbcode-body">can anyone tell me what these tanks are for?
IA
CF </div></div>
DL </div></div>
[img:center][/img]
Old 01-16-2018, 04:53 PM
ban617 ban617 is offline
Since there seems to be a lot of knowledgeable radiator fellas here can you tell me what an “AG”stamp on the fill side & “IA” stamp on the left side means with a 26.5” wide core would fit ...
Thanks Rob
Old 01-16-2018, 04:54 PM
Manual transmission also
Old 01-19-2018, 06:01 AM
I've seen it before. It had a broadcast code of RP (could vary depending on the core). No idea on the application.
Kurt S - CRG
