Old 08-24-2010, 08:45 PM
x  Baldwin  Motion's Avatar
Default Re: Chevy C20 4x4 4 spd pickup
Shaft removal not uncommon sign of front end gear problems or desire to save gas, absolutely a guzzler. Granny gear is a real tree climber, there is not much you can't move with that.
Really clean body , perfect patina !! a little wet sand and rub it out then a coat of clear satin. That's what I should have done with the kids Nova.
Old 08-24-2010, 08:51 PM
mockingbird812's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SuperNovaSS</div><div class="ubbcode-body">My 72 Short Fleet 4x4 has a 4 speed manual. The first gear is fairly useless for standard driving as it is a non syncroed granny gear. Still fun to drive though.
Jason </div></div>
Jason - what are the particulars on your tranny - kind and manufacturer. Was it original to your truck?
Sam...
Old 08-24-2010, 09:22 PM
I wish I could tell you. I have just driven it. I could find out but it may be different since mine is a 1/2 ton.
Old 08-24-2010, 09:25 PM
It should be the sag 465 granny gear as mentioned above, pictured below. standard in the 2500.
pictured below
http://67-72chevytrucks.com/vboard/attac...mp;d=1251925155
Old 08-24-2010, 09:28 PM
Chevy454 Chevy454 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: x Baldwin Motion</div><div class="ubbcode-body">It should be the sag 465 granny gear as mentioned above, pictured below. standard in the 2500.
pictured below
</div></div>
I think you mean Muncie:
http://www.novak-adapt.com/knowledge/sm465.htm
Old 08-24-2010, 10:11 PM
Good stuff guys. Sounds like a decent gear box - tuff, spares available, easy to find parts, not real expensive.
Sam...
Old 08-24-2010, 10:37 PM
budnate's Avatar
budnate budnate is offline
front driveline is most likely out for milage reasons. they were also very wimpy and it didnt take much to twist one up and kill it.
those saddle tanks are very common and ended up in almost all ever made, like Jason says even if you baby it, its like driving muscle, they run through lots of fuel. [img]<<GRAEMLIN_URL>>/beers.gif[/img]
Old 08-25-2010, 01:51 AM
[/quote]
http://www.novak-adapt.com/knowledge/sm465.htm [/quote]
Thats EXACTLY what I mean !! [img]<<GRAEMLIN_URL>>/blush.gif[/img]
http://67-72chevytrucks.com/vboard/a...p;d=1251925155
cool forum for truckers too!!
http://67-72chevytrucks.com/vboard/s....php?p=4154200
