Old 08-13-2009, 08:00 PM
Default Re: Starved For Fuel?
First:
What Eric said: "Next, check/replace the fuel filters in the float bowls." No one on here knows Holley carbs better than Eric.
Then, what Eric said next:
"If the car sits for extended periods, you might check to see if the sock in the fuel tank is getting clogged or varnished up."
It is a classic case of fuel starvation. Replace fuel filters first. If problem persists, remove the fuel filler cap, then remove the fuel line before fuel pump and blow a small amount of compressed air (too much and you could blow fuel up and out of the filler neck) which will dislodge any thing clogging the sock. Re-assemble and take it for a spin. If it is "fixed" then you need to remove the tank and the tank unit and either clean or replace the sock. Blowing back through it is only a temporary "fix".
Old 08-13-2009, 11:38 PM
BTL BTL is offline
Just a thought, is the air cleaner clean?
Old 08-14-2009, 05:33 AM
1968 nova ss 1968 nova ss is offline
thomas,I would definetly trash the ac plugs.Had a similar problem on my stock 396 nova.changed to a NGK plugs;and the miss went away;by the way do you have a inline fuel filter;if so ;change it,besides, these two option only cost $30.oo or so.chris
Old 08-14-2009, 05:53 AM
68CamSS 68CamSS is offline
My L78 would take everything you could give it in 1st gear, hit 2nd pop and bang over 4000, same in third. Always the plugs.
Old 08-14-2009, 09:24 AM
mfchassisworks mfchassisworks is offline
Thomas are you going to Cayuga this weekend? Look for the pure stock / FAST pits I plan on being there on Saturday BLUE COPO Camaro
Old 08-15-2009, 01:13 AM
Thomas Thomas is offline
Nope. That is clean.
Thomas Schilf
'69 Camaro SS, L78, M22, 4.10 Posi
'69 Camaro E/SA
'00 Camaro SS Convertible
'04 Harley FXST
'80 Chevy Blazer (My first new vehicle)
Old 08-15-2009, 01:15 AM
First:
At the recommendation of the performance shop I deal with, I removed the filters and am running without them for testing purposes.
Thomas Schilf
'69 Camaro E/SA
'04 Harley FXST
Old 08-15-2009, 01:16 AM
Unfortunately I only have time to go on Sunday.
Thomas Schilf
'69 Camaro E/SA
'04 Harley FXST
