Old 03-15-2009, 07:34 PM
Alss's Avatar
Alss Alss is offline
Default 074 head repair
In my other post regarding oil pressure in my ZL-1 it has been determined that my heads are also in trouble. Water can enter both heat crossover chambers on the heads..this is not good..can this be repaired? The heads will have to come off,.. but the motor is out so now would be a good time. I can feel the hole between the two chambers ..I can do this on both heads if I stick a bent wire just beyond view in the heat port..I was thinking about filling the passage up enough to cover the break using block grout/concrete..may only be the size of a golf ball when done..anyone have experience with this..Thanks
ALbert
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 03-15-2009, 07:58 PM
beater68427 beater68427 is offline
Default Re: 074 head repair
Have any good pics of them?
Old 03-15-2009, 08:24 PM
Alss's Avatar
no pics as they are still bolted to the block and the piercing into the water passage is on the blind side of the heat crossover curve..I can feel it buyt not see it at least from the intake runner side..maybe after I pull the heads off
ALbert
Old 03-15-2009, 10:15 PM
L78steve L78steve is offline
Removal of the exhaust valves may expose the problem .
Old 03-16-2009, 02:25 AM
Alss's Avatar
induction/exhaust is fine//problem is in the water jacket/heay crossover
Old 03-15-2009, 10:37 PM
I'm starting to think you should have
left the 307 in it
69 El Camino
69 Nova
C7 Vette
Old 03-16-2009, 12:42 AM
elonblock elonblock is offline
Albert,
Depending (which is a big if) on what type of damage you have, as a "home" cure option you can use a high quality epoxy like Marinetex.
I used to work at a cylinder head shop where the guys porting the heads would accidentally grind into a water jacket or breakthrough a port.
We saved a lot of heads using epoxy.It takes some practice to fill the hole and grind/smooth it down. And it can be done with good results.
As a plan B, we had a guy who could really weld aluminum like a magician.
Can you have your machinist take a look at the heads and get an idea of exactly what you are dealing with?
Elon
69 COPO Camaro
Old 03-16-2009, 03:24 AM
JoeG JoeG is offline
Albert,
Elon
Ditto,he makes good sense---this is not the time to rush things.......Forget the grout..
Old 03-16-2009, 02:26 AM
Alss's Avatar
left the 307 in it
NO WAY!!
Old 03-16-2009, 02:29 AM
Could someone have opened up the water jacket to heat riser area on purpose for some reason?
