Old 01-17-2015, 04:43 PM
Paul_S Paul_S is offline
Default Re: SOLD my 1969 SS396 300 Deluxe Post Sedan
...and new hoses/flex-lines too. Looks good.
'64 Nova (400 Series) 2-dr Sedan, 4-spd
Zweigle's -Best "Hots" in the Universe
Old 01-17-2015, 08:18 PM
Rixls6 Rixls6 is offline
Now you can feel safer at the track being all new front brakes and a suspension redo.
I second the idea of replacing the front hoses, but you probably were going to already.
Rick
Don't text and drive.
Old 01-18-2015, 01:42 AM
69 Post Sedan's Avatar
Yes...I plan on replacing the hoses.
I cleaned parts today and found a few factory paint marks.
The letter "M" stamped on the sway bar mount.
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 01-18-2015, 01:48 AM
These are the bushings that were on the upper control a-arm.
Long overdue!
Kurt
Old 01-18-2015, 02:00 AM
You're gonna look great wearing your Bears attire while driving your Post Sedan Chevelle
[img]<<GRAEMLIN_URL>>/headbang.gif[/img]
Old 01-18-2015, 02:45 AM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Kurt-
Double check the lower control arm bolts that run through the bushing and attach to frame - when I re-did my front suspension on the Chevelle the shoulders of the bolts were really worn and needed replacing.
Jake
Jake Dykstra
Dykstra Motorsports
Old 01-18-2015, 04:48 AM
Jake,
Indeed you are correct.....this much more evident with oval bushings as on your Chevelle vs. the round bushings on a 1969 model.
Old 01-18-2015, 02:48 PM
Thanks for the tips...I will inspect those bolts.
With everything I'm seeing, it's no wonder why the front end made so many noises.
I will be sending out the master cylinder but the calipers were decent so I ordered a seal rebuild kit for them.
Kurt
Old 01-18-2015, 03:08 PM
jl8z28 jl8z28 is offline
I have a nos set of upper control arm bushing s
Old 03-10-2015, 03:28 PM
I got my &quot;BA&quot; master cylinder back from Karps.....they did a nice job.
I also plumbed the brake lines for my Hurst Line Lock.......Hopefully I don't have any leaks.
I'm going to remove the protective coating on the new brake lines so they look like the others and then wire the Line Lock.
I plan on getting the front end back together sometime soon
Kurt
