Old 10-05-2015, 06:20 PM
Ryan1969Chevelle's Avatar
Default Re: Gramma's Car: the new project!
This is the first time I have see the value of degreeing a cam during installation.
Bummer that the part is not right on specs, but so important to know now!!
Ryan
Old 10-05-2015, 06:25 PM
Same here. All these decades I always just threw the cam in and assumed it would be right. Rather enlightening to see what I have been missing all these years.
Next episode: What actually goes into the hotdogs you eat. Stay tuned! If you dare! [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
Old 10-05-2015, 07:12 PM
I just installed an old double roller setup from a prior engine and it came back with 1 degree BTDC when installed straight up. So it looks like it is the cam that might be slightly off since I got the exact same result with another timing set.
Old 10-05-2015, 09:16 PM
I spoke with the tech people at Cloyes and the 9-3512X9 timing set I ordered from Summit will hopefully do the trick. The nine-position gear has a &quot;+2&quot; positon that is 1/4 the distance from 0 that the &quot;+4&quot; position is on my old gear.
On the Cloyes gear, that &quot;+4&quot; position that is on my old gear is actually stamped as &quot;+8&quot;. He indicated that is how their gears are stamped: with the actual correction factor, so the final result will be two degrees not four.
Fingers crossed...waiting on the UPS guy now.
Old 10-07-2015, 10:48 PM
Well, here's today's lesson in &quot;You Get What You Pay For&quot;.
The Cloyes true roller set arrived today. Slipped it on in the &quot;+2&quot; position and voila! Perfect 3 degrees BTDC and 109 degrees intake centerline to match the cam card. I was all giddy - I just kept repeating the calculations and spinning the engine and doing it again and again just to make sure I was not hallucinating. I guess there's a reason they charge $100 for the timing set!
Now we can finally get to buttoning up this monstrosity.
Old 10-07-2015, 11:46 PM
earntaz earntaz is offline
Love it when a plan comes together ...
Old 10-08-2015, 12:00 AM
cook_dw's Avatar
cook_dw cook_dw is offline
I failed to mention it previously but you hit the nail on the head. Pay the extra money for a timing set. The cheaper ones will stretch within minutes of running. Most of the time it wont matter but when building a precision engine every little thing matters.. Glad the math is working out like it should. [img]<<GRAEMLIN_URL>>/beers.gif[/img]
Old 10-08-2015, 12:24 AM
VintageMusclecar's Avatar
I went through the exact same scenario with my 302.
Old 10-11-2015, 04:55 PM
All buttoned up and ready to go back in!. One of the members at the PY site donated an old set of 1970 chrome valve covers to the project. I cleaned them up and they really woke up the snazzi-ness factor of the engine.
(Ignore the rusty exhaust manifolds. Hopefully any paint on them will burn off in the first minute or two, and I am aiming toward getting some repro D-port Ramair manifolds and a new exhaust system this Winter).
Old 10-11-2015, 11:04 PM
Well, it's time to stop for the night. Got everything installed. Still need to tighten the trans and converter bolts, install starter, radiator, fan, PS pump, etc. Got a lot done this afternoon.
