Old 02-23-2023, 08:01 PM
Igosplut's Avatar
Igosplut Igosplut is offline
This is the plug. I had a few 375 HP 70s, and was just curious...
WOT
The Following 2 Users Say Thank You to Igosplut For This Useful Post:
L78_Nova (02-23-2023), olredalert (02-23-2023)
  #242
Igosplut's Avatar
Ah, ya beat me to it..Thanks.
WOT
The Following User Says Thank You to Igosplut For This Useful Post:
  #243
Old 02-24-2023, 03:07 PM
L78_Nova's Avatar
L78_Nova L78_Nova is offline
Default 1970 L-78 Nova Restoration; Saga of The Green Bastard
Now some fun stuff... Engine assembly.
You saw the dirty photos... This took some effort to get the block this clean for assembly.
My buddy Dereck Glesby the "muscle' for the job... and the brains... he is an aircraft field service mechanic by trade. He also has all of the trick engine assy and measuring tools to check clearances (rather than using plastigage).
No surprises aside from a little extra effort to set the thrust bearing clearance.
So... after we both misunderstood the Cloyes keyway instructions, I had to build a puller for the crank sprocket which we had installed incorrectly (couldn't wait the couple days to borrow one).
And the pistons are in!
Very light green hue on the cylinder walls is from the Total Seal "Quick Seat" powder for seating in the rings. I thought it couldn't hurt with this block only having been deglazed.
70 Chevelle SS-454 LS-5 M-22
The Following 5 Users Say Thank You to L78_Nova For This Useful Post:
big gear head (02-24-2023), dykstra (02-24-2023), olredalert (02-24-2023), SuperNovaSS (02-24-2023), Xplantdad (02-24-2023)
  #244
Old 02-24-2023, 04:43 PM
L78_Nova's Avatar
Dereck Degreed the Cam.
I always use Cloyes "Hex Adjust" chains in my engines. You can dial the cam in exactly. This is a Crane solid 396 425HP spec cam (I think its exactly the same specs as the 375HP). I Reused the cam that was in the engine as it all inspected perfectly and I had marked the original position for each of the lifters. Plus no break in drama or worry about a bad core. Some of Dereck's fancy tools !
The Following 3 Users Say Thank You to L78_Nova For This Useful Post:
  #245
Old 02-24-2023, 06:00 PM
L78_Nova's Avatar
The oil Pan was replaced with a stock style Moroso as the original was beaten beyond repair from bottoming out on gravel roads
A little clearancing was required on the Moroso baffling to clear the factory windage tray studs.
I also used a Moroso standard volume pump and pickup.
  #246
Old 02-24-2023, 06:12 PM
Igosplut's Avatar
Are those 30 over 402? I took all three 854 blocks and punched them out to 427, years back you couldn't get 402 pistons (oversize).
WOT
Old 02-24-2023, 06:57 PM
L78_Nova's Avatar
Yes TRW 402 + 0.030" (4.155"). I would have to check the bills for date? but this engine was previously re-built and bored prior to my purchase in 97 and the car has been in storage since my purchase until starting into the restoration.
Old 02-24-2023, 07:26 PM
L78_Nova's Avatar
On go the heads... rebuild with New guides, Seals, and fresh Valve job.
The paint shop Is it wrong that I spent hours degreasing every nook and cranny with solvent and a toothbrush
Using the tall intake just because I prefer the looks (I do have the original pancake manifold). Manifolds are ceramic coated. I went with non-smog, really not sure what was correct. For as long as I have known the car it did not have smog but... I've been told ALL L-78's were delivered with smog.
Big D buttoning things up.
dykstra (02-24-2023), olredalert (02-24-2023), scuncio (02-24-2023), Too Many Projects (02-24-2023), Xplantdad (02-24-2023)
  #249
Old 02-24-2023, 09:39 PM
dykstra's Avatar
dykstra dykstra is offline
Saweeeeet!
Dave Dykstra
NCRS#66003
Dykstra Motorsports
L78_Nova (02-25-2023)
  #250
Old 02-24-2023, 11:20 PM
----Like this build a lot. It's your engine, and it's your car. Build it your way or no way! I have never liked the low intakes. I have always heard that fuel puddled up down in the low spots of these intakes!.....Bill S
