Old 11-23-2018, 01:40 PM
Edgemontvillage's Avatar
Edgemontvillage Edgemontvillage is offline
Originally Posted by Canuck View Post
The shrubs came from one of Lloyd’s “hedge funds”
Dad joke...
Old 11-23-2018, 05:18 AM
Canuck's Avatar
Canuck Canuck is offline
“gentleman’s club”.
www.vancouverclassiccars.com
The Following User Says Thank You to Canuck For This Useful Post:
dykstra (12-03-2018)
Old 12-03-2018, 11:49 AM
dykstra's Avatar
dykstra dykstra is offline
Very cool! Looking awesome!
Dave Dykstra
NCRS#66003
Dykstra Motorsports
Old 02-10-2019, 03:44 AM
Canuck's Avatar
Latest piece of shop equipment arrived on Thursday. Haven been smitten by the beautiful results of vapor blasting, we took the plunge and ordered a system in November. A 6 week build wait and our unit shipped late January. Got the machine to our shop And did the setup and test today. Results are amazing. Will be posting more before and after shots.
Lots of cool plumbing.
Nos disc brake pad with some surface rust
And after Vapor blasting.
The Following 3 Users Say Thank You to Canuck For This Useful Post:
markinnaples (02-10-2019), Tracker1 (02-10-2019), YENKO DEUCE REGISTRY (02-13-2019)
Old 02-10-2019, 09:39 PM
He're Paul on the maiden voyage of the VHT VH800P FL Closed Loop vapor blaster, it does produce some impressive results. The machine was made in Lincolnton, NC and was in transit for about a week during its 2,900 mile trek to Blaine, WA.. It must have encountered some cold temperatures along the way because it arrived with freeze damage. It is tested at the factory and wasn't fully drained prior to shipping so the hose nozzle split and one of the pressure T-fittings also cracked and spewed water on startup.
Freeze Damaged T-Fitting
Freeze Damaged Nozzle
Old 02-10-2019, 10:30 PM
mockingbird812's Avatar
Wow, unbelievable results. Congrats on the new toy!
Sam...
Old 02-11-2019, 02:54 PM
enio45 enio45 is offline
loving it!!!!!!!!!!!
can i have it?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 02-11-2019, 03:34 PM
The vapor blaster produces a very clean, sealed surface on cast iron and steel leaving a burnished-like sheen. For most applications this is fine however with cast iron its a brighter finish than I prefer so IMO cast parts need to be treated to dial-in that brown-gray fresh casting color range. Following vapor blasting I use a semi-solid oil and, in the case of spindles and steering arms, bake them at 400 degrees for about 90 minutes to achieve the fresh cast look. As the oil bakes into the cast it heat seasons the metal and also serves as a natural rust inhibitor.
Freshly vapor blasted spindles and steering arms.
Baking in the "Easy-Bake" oven
Before and after heat seasoning (The seasoned spindle appears much darker in the photo than it does in person)
Heat seasoned steering arms
The Following 2 Users Say Thank You to Edgemontvillage For This Useful Post:
HawkX66 (02-12-2019), Xplantdad (02-11-2019)
Old 02-11-2019, 04:28 PM
Canuck's Avatar
I hope Sherrie was out when you used the ovens for your baking party?
Old 02-11-2019, 06:07 PM
To keep the peace my Easy Bake (read toaster oven) is for use with parts only.
