We cc'd the 1975 6X-4 cylinder heads today. One head had chambers all at 94.5cc and the other head were all 93cc. A Pontiac engine guru plugged all the technical info from the build into his desktop dyno and it comes out to 9.44 to 1 compression and a predicted 390 horspeower at 4500 rpm and 480 lb-ft of torque at 3400 rpm. Compare that to the SD455 net rating with 290 horsepower at 4000 RPM and 390 lb-ft at 3600 RPM. [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
Sure is pretty Eric ...
You've never lived until you've almost died -- for those who fight for it, life has a flavor the protected will never know! |
No problem with the cc difference. Just bore one size .030 an the other side .060.
Jason |
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SuperNovaSS</div><div class="ubbcode-body">No problem with the cc difference. Just bore one size .030 an the other side .060.
Jason </div></div> That would go great with a swapped main cap or two! [img]<<GRAEMLIN_URL>>/grin.gif[/img] |
I was getting an old pair of lifters ready to use for degreeing the cam: popping the clip and taking out the internal spring and replacing it with a solid washer, Of course I proceeded to slip with the screw driver and jam it halfway through my finger. OUCH!
It seems that the mechanical dieties always require some type of blood scarifice for every engine I have ever assembled. This one was no different. I proceeded to bleed all over the short block looking for a rag to wrap my finger with... The worst one was the time I tried to install an oil pick up into a smallblock Chevy oil pump. I slipped the open end wrench over the pick up flange and took aim with a 32 oz. ball pean hammer. I swung. Perfect on-target hit - right onto my thumb nail. [img]<<GRAEMLIN_URL>>/eek.gif[/img] |
Eric.....you are truly a craftsman in every sense of the word! Outstanding job!!
1970Camaro Z28 |
Here's a question for you camshaft gurus out there:
We started the process of degreeing the camshaft and have come up with some numbers that don't seem to match the tech card on the Summit 2802. ![]() Intake cam timing @.050 is supposed to open at 3 BTDC with intake centerline of 109 degrees What we got @.050 was: intake opens at 1 degree BTDC with intake centerline of 110.5 degrees. ![]() Exhaust cam timing @.050 is supposed to open at 56 degrees BBDC with exhaust centerline of 119 degrees What we got @.050 was: exhaust opens at 54.5 degrees BBDC with exhaust centerline of 116 degrees These results were the average of 3 tests.= for each set. I used two solid lifters. So I tried using the three position crank sprocket at the advanced position (it has a "+4" stamped there) and it moved the intake opening to 9 degrees BTDC from 1 degree. Now, instead of being 2 degrees retarded from the 3 degree spec, it is now 8 degrees from its original position (or 6 degrees advanced from the 3 degree BTDC spec). So I assume that is way too far in the other direction for an adjustment. I guess I have to buy another double roller set with a 9 position keyway and try to adjust from there. Cloyes makes a nice one that is around $95 from Summit. I am not a math whiz so I am guessing that a 4 degree crank sprocket advance position actually moves the cam 8 degrees due to the fact that the crankshaft rotates twice for every single rotation of the cam? What about an offset cam sprocket woodruff key? The smallest increment they sell is 2 degrees (Mr. Gasket). Here is my question: will a 2 degree cam key move my final dial reading two degrees to the preferred 3 degree spec or will it add 4 and make it 5 degrees total? Help me Obewan Kenobee, You're my only hope... ![]() |
I would really like to pick your brain on how your process of finishing the carb body.. [img]<<GRAEMLIN_URL>>/grin.gif[/img]
Nice work.. Not many realize the excellence of your plating abilities.. |
Welcome to the wonderful world of mass produced parts. [img]<<GRAEMLIN_URL>>/frown.gif[/img]
Just outt'a curiosity, what brand is your existing timing set? Assuming your 1st attempt was straight up?--of so, I'd save yourself a lot of unnecessary aggravation and install it there. It's basically within 2° of spec. With the 3.42 screw in the back, running the cam a couple degrees late won't hurt a thing, plus it'll help ward off spark rattle. |
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: VintageMusclecar</div><div class="ubbcode-body">Welcome to the wonderful world of mass produced parts. [img]<<GRAEMLIN_URL>>/frown.gif[/img]
Just outt'a curiosity, what brand is your existing timing set? Assuming your 1st attempt was straight up?--of so, I'd save yourself a lot of unnecessary aggravation and install it there. It's basically within 2° of spec. With the 3.42 screw in the back, running the cam a couple degrees late won't hurt a thing, plus it'll help ward off spark rattle. </div></div> I agree. |
