Old 06-10-2015, 08:21 PM
EZ Nova EZ Nova is offline
Default Re: The Flying Dutchman 2014 New Thread!
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: sYc</div><div class="ubbcode-body">IMO, the main reason the same combos run better times today then back in the day is A. track prep and B. tires. </div></div>
Tom, there is alot more then just that? Camshaft tech, fuels and lubricants as well as what the factories are doing all help with making the &quot;average&quot; car faster then it would have been back in even the '80's. Fuels even. Look at the Oxygenated fuels and how they alone can effect ET. I've personally seen a 8 second N/A SB pick up 2 tenths from going from C16 to Q16 when he jetted up accordingly.
There is so many other things that we do that I can't get into either, Pro-flite trans, Ti wheel studs, carbon brake, ceramic bearing etc. that help the whole package, yet some people wouldn't even look into these areas or notice till you point it out, yet those there can be 1/2 a second in ET.
'78 Z28 4sp being restored
'70 W30 convert TRIBUTE
'66 CANADIAN Nova SS Race Car
'69 FIREBIRD Tubbed Racecar
Old 06-10-2015, 10:00 PM
I think??? Tom was talking about how fast the Stock Elimintor cars were 40 years ago compared to how fast the &quot;stock eliminator&quot; cars of today are and how much the word &quot;stock&quot; is stretched.
Old 06-11-2015, 02:46 PM
Ya possibly, never thought of that. opps
Old 06-11-2015, 03:47 PM
10.47 ET is pretty strong for that setup...would like to see it run [img]<<GRAEMLIN_URL>>/[/img]
wilma
Old 06-11-2015, 04:01 PM
real strong!
Old 06-12-2015, 03:06 PM
Sorry guys, took it apart and sold off the top end, cam and some other parts. Still have shortblock and going into it sometime this year. Got a set of stock 840's and 163 intake for it, just for the OEM look.
Funny, I did end up putting a 10 point cage in the car, sold off the M-21 for a 'glide as I KNEW I would end up breaking that trans, and bought the &quot;POLISHED SNEAKERS 427&quot;! That artical is gone now, but YEARS ago, Patrick Budd built 2 low-buck BBc's. 1 was a .030 over 427 (MINE) for Lee Martin, and a .030 454 cor another guy. Basic low buck stuff for a total of 5 GRAND in each. Basically there OEM shortblocks with TRW pistons, OEM OVAL port heads, solid lifter cam and aftermarket intake. My 427 was set up to run Nitrous and had 12.8-1 compression, cam was right around 600 lift, just plain old solids.
Lee ran this motor, 3500 converter, 4.10 rear, DOT tire and 3500+ lbs Buick regal. FIRST time at the track this car went 10.90's. Out-of-the-box- Holley 850 and HEI distributor. Shifted at 6500.
I PUT this 427 in my '69 Nova. REWORK Holley 800 form my other motor, 2 speed with 5200 converter, 9&quot; SLICK and 4.56's. This ALSO ran 10.40's. Patrick told me that the &quot;215&quot; heads were about a 60% effort due to Lee's limited knowledge and the car being set up for 250 hit of Nitrous. I think if we spent some time and played with it, I think I could have gotten LOW 10.20's maybe even a 10.TEEN in the right conditions. Reworking the heads, changing the cam, converter and gears, I bet there was a 9 in that little 433.
This too is going back together this summer, I sold off some of the stuff (block and some other odds n ends) to a &quot;Nostalgia&quot; class racer and that stuff went over to run LaMans in France VINTAGE series.
Side note: The 454 with &quot;781&quot; heads, N/A cam, 4.10's and 3500 converter ran 10.30's shifting at 6500. BOTH ran thru mufflers and DOT tire and both over 3500 lbs. The owner of the 4454 DID change to alum head and matching intake, AND SLOWED DOWN!!!!
John
Old 06-12-2015, 03:08 PM
Umm wonder what you guys will say WHEN my &quot;052&quot; ZL-1 motor with &quot;074&quot; heads and &quot;198&quot; intake runs MID/LOW 9's in the same '69 Nova?
Old 06-12-2015, 04:51 PM
VintageMusclecar's Avatar
Patrick Budd: Polishing a Set of Sneakers
Great article.
It's not as hard as most people think to put a well-sorted BBC deep into the 10's--even the &quot;baby&quot; rats.
Back in the `80's the staging lanes at our local tracks were filled with 10 second bracket bombers, and there were more crate LS7 engines than you could shake a stick at. Those engines make an <span style="font-weight: bold"><span style="text-decoration: underline">honest</span></span> 480-ish HP in stock form and will make low-mid 500's with a cam and intake swap. Add a halfway-decent prepped car with a converter and a gear and you'll run 10's until the cows come home.
There was one guy with a BONE stock (save for headers) `69 L78 Nova with 400 Turbo and 4.10 gears, and with sticky street tires he was running high 11's-low 12's depending on the weather.
John's numbers are more than plausible.
Old 06-12-2015, 07:26 PM
Thanks, that's it! I haven't seen it in 2 years, but I did have it printed out at home. I'm only about hour from the Falls boarder and been to Pat's shop, ProCars when he had it a few times.
People sometimes don't look at &quot;THE TOTAL PACKAGE&quot;, and therefore HURT performance as noted in in there when Mike switched to Merlin heads and Team G intake, PLUS going up a point in compression, THE CAR SLOWED DOWN A 2 TENTHS AND 2 MPH. That's why when we were putting my motor together, my guy recommend the SMALL 660 roller over the typical BBc 714 I had that everyone was using.
Old 06-15-2015, 11:45 AM
bbbenny bbbenny is offline
Yes, technology changed with the years. In the late sixteys if you had car that ran in the 12S. You had a good car. But today, your grand mother wouldn;t drive that car. I;m not braging in any way. But I run a full unlitened body car. 3350 lb. no driver. All motor, foot brake, and I;m doing a 10:31 Et at 133 MPH. And that;s lunching the car at 1,800 RPM;s. Thanks The Dutchman
Thanks Benny
Enjoy; orginal cars,with orginal drivetrains and docs. bblocks are my favorite.
