Old 07-14-2008, 07:22 AM
67rscoupe 67rscoupe is offline
Default Re: 68 396 water pump rebuilt
why dont you rebuild it yourself?its easy to do.a kit cost something like $65 from a corvette parts place called ZIP.it says you need a small shop press but a nice vise will work just fine.
it will cost you $20-$25 for shipping alone if you send it to someone.
here is a kit for a 427 the same year 1968.this should be the same.
http://www.zip-products.com/Zip/productr...770B263295F4A5E
Old 07-15-2008, 05:36 AM
1968 nova ss 1968 nova ss is offline
I will ask Arthur this week about any modifications beyond stock;most big blocks I have owned are ok in temp when cruisin;but seems to heat up more than I want at idle or at high speeds.Chris Teed
Old 07-15-2008, 04:01 PM
JRSully JRSully is offline
I have a stock L78 396 in a Nova,a stock 3 core rad, stock non clutch 5 blade fan, stock rebuilt original water pump, 180 stat and it never goes above 180 unless I am sitting in dead stopped traffic for more than 15 minutes
71 Porsche 911 Targa
Old 07-15-2008, 11:56 PM
Mr. Chevy's Avatar
WOW Not me.. I'm running a 4 core radiator w/stock water pump and stock style - non clutch fan, 180 degree stat in a stock 1970 L78 motor in my Nova. I even put in a bottle of water wetter and I run 190-200 while moving on a hot day and she will creep up to 210 when sitting idling.. My cooling system is free and clear also, no plug ups or problems internally...
Your Lucky!!!!
Rich
Old 07-16-2008, 03:46 PM
Rich, I think the key is to make sure you have completely bled all the air bubbles out of the system/engine. BB Chevys tend to develop air "pockets" in the rear of the heads which can be tough to get out sometimes. I learned that the best way is to cure it is to jack the front of the motor/car, and pour coolant slowly and dirtectly down the front of the intake/Thermostat housing so it flows right to the back of the heads/engine, until it fills just about to the stat flange, then install the stat and fill the rest of the radiator. I was running hot also until I learned of this method and I never had another overheating problem by using it. SULLY
Old 07-16-2008, 04:20 PM
Mr. Chevy's Avatar
Sully, thanks for the info.. I've never heard of this method.. I'll have to give it a try..
Rich
Old 07-16-2008, 04:59 PM
budnate's Avatar
budnate budnate is offline
also a old trick I was shown years ago and works well is drill a 1/8 or so little hole on the edge of the stat to let air through, on a system that was serviced, it wont affect running temps and keeps you from melting down a motor,
Old 07-17-2008, 12:37 AM
Sully,that's good info there.I will have to try it on my other 68 nova ss 396 currently.It runs about 190 temp at cruisin speed with 3;42 gear.but it will crank up 220 temp in traffic and that only at a short rate of time with new 4 core radiator and stock rebuilt,Just don;t want to have any cooling problems with this 396/375 hp nova ;with cloned over 842 aluminum heads and such and a decent amount of money forked in the motor to compete in the purestock drags races;wanna keep it runnning good and cool.chris teed
Old 07-17-2008, 03:01 AM
We put a Stewart Hi-perf pump on our 68 BB Nova....and their matching 160* t/stat. We have a 4 core OEM style radiator stock shroud and a steel fixed 6 blade fan...car runs about 170-175*...will go to 180-185* if it idles for awhile or traffic backs up. The engine has aluminum heads which also seem to help it run cooler...I also run some of the cars with just the t/stat body and remove the guts...acts like a restrictor...this seems to work ok, too. The black L78 th400 car runs really cool...last 2 nites at different cruises it ran at 170-175*...Harrison 4 core, stock BB pump, stock shroud and 6 blade flex fan...you really have to try to get it to 180*...maybe we just live right
