![]() Dedicated to the Promotion and Preservation of American Muscle Cars, Dealer built Supercars and COPO cars. |
#11
Mr. Gasket 1293
$16.69 Max width 3.00" Steel Plated Summit Jim
69 Los Z11 68 SS/RS 396/325 68 Los Z28 ![]() |
#12
You can run them on the street, but the ride is noticeably stiffer. Also, I have the Mr. Gasket set, they are a bit too wide and will hit your frame rails when the car squats. You will need to grind about a 1/4" off the ends that face the c/l of the car - both sides, ie; all 4 plates!
Marlin 70 Yenko Nova-350/360, 4speed M21, 4.10 Posi (Daddy's Ride) 69 SS Nova-396/375hp, 4speed M20, 3.55 Posi (Benjamin's Ride) 67 RS Camaro-327/250hp, 2speed Glide, & 3.08 Open (Danny's Ride) |
#13
The DH method.
Don't mistake education for intelligence. I worked with educated people. I socialize with intelligent people. |
#14
I have the spring clamps on my 69 RS/SS and it is a good bit stiffer for daily driving. They're off in 5 minutes so no big deal.
#15
I've been running a set of DH clamps on my 68 for a few years now. I use them with the Lakewood bars..What a difference.The car hooks harder and goes straighter...
![]() ![]() Steve |
#16
The clamps will be going on shortly, noticed the front end of the leafs are a bit "tweaked" already, going with the DH method. Anybody use an aftermarket pinion/front of diff. snubber,? seems the factory one ain't cuttin it and some marks are being on left on the floor pan above the rear U joint. Thanks for the tips/pics. SULLY
70 L78 Nova Fathom Blue,Bench, 4spd, F41, 3:55 71 Porsche 911 Targa |
#17
Maybe if you took your right foot out of the "water pump" you wouldn't damage so much hardware
![]() ![]() luv, wilma
02 Berger 380hp #95 Lots of L78 Novas Join National Nostalgic Nova! 70 Orange Cooler 69 Camaro |
#18
The car has 2 speeds, off and floored, parts be damned
#19
The spring clamps will help with the shaft to floorboard issue. On one of my first runs down the strip, I noticed that the car was 'settling' at the big end - enough for the shaft to just lightly rub the floor board. Stronger springs, some clamps, some wedges, or a snubber would all work.
#20
Like M said, the clamps should help subdue axle wrapup, and keep the floor safe...if the front portion of the leafs can't bend/seperate, then the axle itself can't move...unless it moves within the u-bolts!
