Old 04-30-2008, 06:45 PM
Default Re: Found: 66 SS 396 Chevelle
You know, that is what I thought. He must have gotten that number wrong, because it should be a 138 like the Trim Tag, right?
John 10:30
Old 05-01-2008, 03:18 AM
x  Baldwin  Motion's Avatar
If the Vin is correct it is for a 4 door 66 Chevelle.
Mike
First Digit: Division of General Motors
1 - Chevrolet
Second and Third Digit: Series Designation
31 - Chevelle 300, 6-cylinder
32 - Chevelle 300, 8-cylinder
33 - 300 Deluxe, Chevelle, El Camino, 6-cylinder
34 - 300 Deluxe, Chevelle, El Camino, 8-cylinder
35 - Malibu, Custom El Camino, 6-cylinder
36 - Malibu, Custom El Camino, 8-cylinder
38 - SS 396, Concours, 8-cylinder
Fourth and Fifth Digit: Body Style/Model
11 - 2-door sedan
17 - 2-door sport coupe
35 - 4-door station wagon, 2 seats
36 - 4-door station wagon, 2 seats, dual tailgate
39 - 4-door sport sedan
67 - 2-door convertible
69 - 4-door sedan
80 - 2-door sedan pickup
Sixth Digit: Year of Production
6 - 1966
Seventh Digit (Alpha Designation): Final Assembly Plant
A ~ Atlanta, Georgia
B ~ Baltimore, Maryland
F ~ Flint, Michigan
G ~ Framingham, Massachusetts
K ~ Kansas City, Missouri
Z ~ Fremont, California
*and I could not find that trim code either.
Old 05-01-2008, 03:20 AM
some chevelles may have a 138 TT but a 137 vin (not '69's)
have him check that trim code also.
Old 05-01-2008, 06:41 AM
Well, talked to my b-i-l tonight, and he thinks the VIN tag may have been changed. I guess the guy who inherited it said it has "SDN" on the title.
John 10:30
Old 05-01-2008, 08:40 PM
Are there hidden VINs on 66 Chevelles?
If so, where?
John 10:30
Old 05-02-2008, 01:10 AM
There is one on the top of the frame at the rear wheel area,pull the rear wheel on the driver side,take a mirror with a handle and you should be able to see it.You may have to clean dust or dirt off but there should be one there.Not sure as far as the body goes but I bet there are somewhere. I had someone tell me before on the inside lip of the trunk on the driver side under the rubber gasket there is one but I never seen one there. Says it is stamped in the metal in the groove about 1 foot from the top edge right in the groove!
Old 05-03-2008, 11:06 PM
Anyone else know of hidden VINs?
John 10:30
Old 05-04-2008, 01:23 AM
CT Mark CT Mark is offline
No hidden vins on 66's except the partial vin on the frame mentioned above. That's pretty much impossible to see when the car is on the frame. There would also be a partial vin on the tranny case...usually on the top. Again, hard to see with the trans in the car. Good luck!
Mark
66 Chevelle SS
http://www.chevelles.com/showroom/da...velle_DL_2.jpg
Old 05-04-2008, 02:43 AM
Thanks BB and 66.
John 10:30
