Old 04-09-2008, 04:34 AM
Steve Shauger's Avatar
Administrator
Default Re: m22 how to tell from m21?
M22 transmissions built late Oct of 1969 had a C designation following the build date. Those transmission built prior did not have that identifier
[/ QUOTE ] Steve, M22s used the C in 1968 date production[69 model year]
I meant 1969 production. The identifier was implemented Oct 21st of 1968 for 1969 production. Is that better
www.vintagecertification.com
427king 427king is offline
Yenko Paid Member
Ct. ???? huh, isn't that where 427King lives????
[/ QUOTE ] Yeah, but he said "real good price" so that eliminates me as the seller
Old 04-09-2008, 04:35 AM
wheelhop wheelhop is offline
I was thinking that but couldn't say it!!!!
Old 04-09-2008, 04:47 AM
vettem vettem is offline
would you one sell for 1200.?(rebuilt)
Old 04-09-2008, 04:58 AM
Yenko Paid Member
[/ QUOTE ] Keep an eye on the parts for sale section, there are some serious deals on some real rare and desirable stuff coming up real soon. You may be amazed.
Old 04-09-2008, 06:29 AM
396/425blr 396/425blr is offline
any truth to a drain plug being a idenifier? dennis
Old 04-09-2008, 07:04 AM
crash crash is offline
The begining of the 1970 model year engineering drawing changed to put a fill and drain plug in every main case...
A lot of customer what drain plugs, so I have drilled and tapped many cases to 1/2" NPT, and I know a lot of rebuilder that do the same...
The only positive way of determining if you have and M-22 is to pull the side cover to see if the gears helical angle is 21* (M-22) or 39* (M-20-21)... Hope this helps... Crash
Old 04-09-2008, 07:17 AM
Z28DZ Z28DZ is offline
Sort of. M22 did have the drain plug, however many M20/21's had a drain plug retrofitted for ease of gear lube changes.
Here's a pic of the gear sets showing the teeth angles:
M20/21:
M22:
Old 04-09-2008, 08:01 AM
...note NO overlap of M22 gear teeth on the same gear while M20/21 teeth overlap the next tooth in sequence..
Old 04-09-2008, 06:19 PM
firstgenaddict's Avatar
Helical vs straight cut gears... that's what makes it the "rock crusher"
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
