Old 02-16-2008, 11:04 AM
HiHorse HiHorse is offline
Default Re: shifter hole
in that case a torch will do the trick
Old 02-16-2008, 11:54 AM
Don't pay attention to these smart asses. Yes, the originals were indeed cut with a torch. You obviously want to know WHERE to cut out. I believe that if the tunnel is original, you will find four little dimples representing where the four screws go to hold down the shift boot trim piece. Drill those out, screw the trim piece in place, and you can use it as a template to mark the hole.
Hope that helps. If not, let me know. I believe I have some template instructions at the office.
Lynn
Old 02-16-2008, 05:17 PM
396L35's Avatar
396L35 396L35 is offline
Here are some photos to help you cut your hole.
Mark
Old 02-16-2008, 06:15 PM
allcamaro's Avatar
allcamaro allcamaro is offline
That hole is for a 1967 car and probably a automatic not correct for a 69 4speed.
1967 Nova SS L30
1967 Chevelle L79
1969 RS Z/28 Red
1969 RS Z/28 Lemans Blue
1970 Z/28 Blue
1967 RS Convertible
1968 Camaro SS
1992 GMC Yukon 30166 miles
Old 02-16-2008, 06:23 PM
allcamaro's Avatar
Ok I found one you should be able to use. This is from a original 1969 SS 4speed car from california and is a LOS car.
1967 Nova SS L30
1967 Chevelle L79
1969 RS Z/28 Red
1970 Z/28 Blue
1967 RS Convertible
1968 Camaro SS
Old 02-16-2008, 06:37 PM
allcamaro's Avatar
Another
1967 Nova SS L30
1967 Chevelle L79
1969 RS Z/28 Red
1970 Z/28 Blue
1967 RS Convertible
1968 Camaro SS
Old 02-16-2008, 07:52 PM
396L35's Avatar
Ok how about these two pictures...
Mark
Old 02-16-2008, 08:32 PM
budnate's Avatar
budnate budnate is offline
if i recall right a auto hole only needs to be trimmed on the left up to 1/4" from the screw hole on the left and the shifter factory or a hurst console shifter clears properly and the factory dust boot lands back down on the factory screw holes. if you look at the two pics you will see the 1.5" diff, no need to go crazy cutting, 10 mins with the jig saw does the job
B.
Old 02-17-2008, 04:10 PM
poster not looking for auto hole,....4spd=torch
Old 02-18-2008, 07:25 PM
This photo from a original Z28
