Old 02-02-2008, 03:10 AM
HiHorse HiHorse is offline
Default Re: Original stamping?
P9P10 Muncie build decodes as...
P---Muncie assembly plant
9---1969 model year
P---Sept.
10--10th day of Sept.
This is an early build trans, Sept. 10th of 1968 for use in a 1969 model year car...
It has no A-B-C ratio designator because that didn't start until the end of Sept. 1968 calendar year, a little more than a month later... Hope this helps... Crash
I have a Muncie with build date P9R03B, this one is Oct 69 based on the VIN derivative.
I would bet that the trans came out of a 69 camaro, since production was extended until Nov of 1969. Again camaros built in this time frame were still considered 1969 model year camaros. The VIN is what identifies the year in which it was built. The Vin most likely starts with 69xxxx or 70xxxx.
Actually this is from my 1969 Corvette built Nov. 69
Old 01-24-2008, 07:19 PM
dechev dechev is offline
Thanks to all who responded to my questions. Always nice to have more information to work with and see if a person is on the right track or not.
