Old 01-03-2008, 07:41 PM
DarrenX33's Avatar
Default Re: NGK spark plugs..
Tom;
Set them at .035" if the car still has an OE points style distributor.
Eric
Hmmm... Hey Moe, does it matter if the innards are Crane or Pertronix?
1969 Z28
1972 Corvette
Old 01-03-2008, 08:24 PM
VintageMusclecar's Avatar
Darren;
IMO, no.
I've personally never found much benefit in fat plug gaps, all they do is work the rest of the ignition components that much harder. I used a Crane Xr-1 conversion on my 496, and with Autolite plugs gapped at .035", it never missed a beat on the dyno.
Eric
ps.
The name's "Curly."
Old 01-03-2008, 08:30 PM
DarrenX33's Avatar
Cool. Sounds like I golden..
Ok, I'll be Larry.
1969 Z28
1972 Corvette
Old 01-03-2008, 08:47 PM
I used NGK in my old 427 nova, great plug.
Jake is my grandson!!
Old 01-03-2008, 09:25 PM
Chevy454 Chevy454 is offline
Darren;
IMO, no.
If anything, with compression you might need to tighten the gap a tad...or help cheat your power up/down as needed...we've played around with gaps a little in our Camaro, and @ 12.2:1 I wanna say we're ~32? [Lemme check my notebook before anyone takes that as the Gospel! ]
But as someone above said, switching from our coveted AC plugs to NGK's cleared up a big end stumble, and showed power on the dyno, and we've never looked backed!
Old 01-03-2008, 09:46 PM
666 the legend 666 the legend is offline
NGK is a great plug but..I use the CHEAPY Denso $1.98 plug [gap .35]in my NOVA..[970 HP N/A] and it starts up everytime and havent changed a PLUG since last May..!! is 9.50 ET all day long..at 3,600 lbs..!!
Old 01-03-2008, 09:50 PM
L78steve L78steve is offline
Are the iridium plugs worth trying?
Old 01-03-2008, 10:29 PM
I try whatever WORKS...!! as long as you have the RIGHT HEAT RANGE...and it runs GOOD and DEPENDABLE...Thats all that matters to me...
Old 01-03-2008, 10:45 PM
mudjnky mudjnky is offline
I need to replace the plugs in my Wifes car and after reading this I'll give the NGK's a try. Does anyone know which plug would go in a GM crate engine 454/420HP, iron head? I'm pretty sure that wouldn't be in the NGK catalog.
Old 01-03-2008, 11:19 PM
PeteLeathersac's Avatar
A couple side notes to the superiority of NGK plugs;
Not sure if the same in the States or not but new offshore produced vehicles coming into Canada sometimes show up with Champions installed as 'original equipment' instead of the actual spec NGK's to save on import taxes!.
I believe they ship the Champ plugs and a few other simple items from here to Japan or wherever the production plant is so a lesser percent of the car is considered produced offshore hence the lesser import taxes.. Of course the Champs run like s**t in many applications and are quickly changed to the spec NGK's by service techs in the know.. This isn't publicised by the manufacturers for obvious reasons also not spread to the dealer level either to keep them from changing them under warranty!.
Also to NGK's credit, they're all I use on the old two-stroke racing snowmachines anymore too.. With mixed or injected oils, Champs and others foul very quickly in comparison to a set of NGK's!.
~ Pete
