Old 01-03-2008, 12:38 AM
Default Re: 63 Muncie M20 Transmission Pat Pend
Larry,
This is the typical location for a VIN derivitive on an early T-10. Sometimes they got stamped a little further back on the front edge of the extension housing. This one was from a '62 Atlanta passenger car. (Dec '61 build)
Old 01-03-2008, 04:38 AM
lbnaz lbnaz is offline
Hello, I found this vin on the front of the WL 73 2 trans. Thanks for all the imfo, Larry.
Old 01-03-2008, 06:57 AM
Larry, I have no idea what those numbers are. But I do know that a Nov '63 T-10 was never installed in a new Chevy. They were switched to Muncies during April '63. BOP and Studebaker may have used them later into '63 and '64 production? The spline on the main shaft and the gear tooth counts could provide clues.
Verne
Old 01-03-2008, 07:44 AM
John Brown's Avatar
Studebaker B-W's had a input with a larger diameter for the pilot bushing and longer snout for the pilot than chevys. Otherwise they looked the same.
John Brown
Old 01-03-2008, 06:54 PM
3macs1 3macs1 is offline
The "directive" for VIN derivitives on blocks and 4-spds began in '62. All the Corvettes have them (one plant) but the practice was sporadic at the Passenger plants. I'm almost certain it was not an inspected procedure, therefore it was easily by-passed by lazy line workers. It was still sporadic through '64! So, unfortunately if you look at a hi-perf 62-3-4 car and it does not have the VIN derivitive, it does not mean it's not the original motor or trans! And even when they did stamp it, there was no "set" formality, meaning some had the plant letter designation preceeding the sequence number and some did not. There were a lot of variations in the font sizes and character styles, and some were gang stamped and many were individually stamped.
I have a pretty good collection of original examples, so if you ever run into one you're not sure of, just run it by me. I can probably tell you if it's real or not.
Verne
Hi Verne:
From what I have seen up here you could add 65 and 66 to that list. I cannot remember seeing to many of them stamped in passenger cars.I know my 66 impala trans has no vin on it and it is original.
Old 01-03-2008, 07:24 PM
I'll take your word for it because I've never collected data from those years. From 62-64 the passenger car VIN stamping only applied to "hi-perf" engines, which meant 300hp and above. That's why I made the comment earlier that a '62 T-10 with no VIN might have come from a 250hp 327. Or it could have just come from a plant that didn't bother to stamp them.
Verne
Old 01-03-2008, 10:09 PM
Fast67VelleN2O's Avatar
Buick Grand Sports 65-66 took a borg warner T-10 with GS stamped on the tail shaft. Iron case aluminum tail shaft. I have owned two of those transes. I am sure other Buicks up to 66 have had them as well.
Day 2 is Life.
