Old 12-11-2007, 01:10 AM
P.J. P.J. is offline
Default Re: rear end info
Yes its 42 1/2 centre to centre
PJ
Old 12-11-2007, 08:01 PM
A few years ago,I found a #341 coded COV rear for sale at Morris.
The seller told me it was exclusive to the 70 Camaro,not just by the axle code,but by the size of the #341 housing as well..I was stunned to hear that and asked in what way.He showed me,and said he was going by what someone from nastyZ28 told him what to look for,& recommended I contact that person to learn more.I did eventually contact him and he was very nice about it & told me the measurement differences were longer due to the new Camaros bodystyle.
I have a friend with a 70 Nova w/a #860 CBS rear,so we measured his and I compared it to the measurements I took off the one at Morris,which did conflict with our precise figures,give or take 1/16".
<u>COV</u>
Axle shaft length 30-3/16".
Axle tube flange to flange 55-1/4".
Spring seat center to center 45-5/16".
<u>CBS</u>
Axle shaft length 29-9/16".
Axle tube flange to flange 54-1/4".
Spring seat center to center 42-7/16".
I honestly don't know if this is a special secret or just misinformation,as I have not read about it elsewhere.But I don't frequent the Camaro/Nova forums as much &amp; would like to hear what others have found on theirs.
Old 12-11-2007, 09:13 PM
Kurt S Kurt S is offline
No mystery at all.
341 is just the center section. It can be used in any application that didn't need the top mounting points (like Chevelles used). Assemble with the correct axle tubes and components and ship.
Kurt S - CRG
Old 12-11-2007, 09:50 PM
That does make sense.
So the minimal measurement differences could just be due to how the workers assembled the components into them?..or even wear/age?
Old 12-12-2007, 08:57 AM
One is a Nova axle, one is a 70 Camaro axle. They don't interchange.
Kurt S - CRG
Old 12-12-2007, 07:25 PM
Those I get.
I was referring more on the varying axle tube related measurements.
Old 12-17-2007, 08:40 AM
I'm missing what you are referring to.
Kurt S - CRG
Old 12-17-2007, 07:30 PM
I'm asking about why there is a measurement difference in the spring seat center to spring seat center,and the flange to flange areas on the two rearend examples I posted.
Could it be due to age,wear or how far the assembler just decided to intall the tubes?
Thought maybe this could be a way to identify a rearends designated vehicle application/year useage for either Nova or Camaro if the stamped application code is not readable.
Old 12-19-2007, 12:27 PM
OK, that doesn't change my answer. The measurements are way off because they are two non-interchangeable axles. It *is* how to ID the axles.
COV is a 70 Camaro axle
CBS is a late 69 Camaro / 70 Nova axle.
Kurt S - CRG
Old 12-19-2007, 09:12 PM
Thanks Kurt.
