Old 10-16-2007, 07:27 PM
HEMIBEE HEMIBEE is offline
Default Re: Removing overspray from wiring.
i like to use a sonic cleaner for all rubber and wires, you can buy a small sonic that holds and heats 1-2 gallons of water and add some simple green (this also stops corosion) it does wonders to rubber parts and wiring harnesses, cleans inside and out and you dont need gloves, also works grreat on carbs and alternator parts you name it.
Rich Straub
raiv 69 judge, ra3 70 judge, 71 judge,74 SD trans am,71 cudas, 67 189 Corvette roadster, Quicksilver 68 HURST
z-10 396 camaro, 69 HEMIBEE
Old 10-17-2007, 05:35 AM
smac77 smac77 is offline
Acetone works good too, doesnt seem to dry out the wiring like lacquer thinner.
After you use thinner or acetone, use peanut oil or some fluid film on a rag and wipe everything down... it will restore the flexability and keep it from drying out.
Old 02-22-2008, 04:59 AM
Barrier Blue Barrier Blue is offline
I've always used fine steel wool.
When I'm paid, I always follow my job through...you know that.
Pontiac - We Import Excitement!
