Old 09-21-2007, 02:49 AM
DaveC68's Avatar
DaveC68 DaveC68 is offline
Default Re: 70 Chevelle radiator tank codes
pic2
Dave C.
68 SS396 Camaro
69 SS396 CB Chevelle Conv.
70 340 Dart Swinger
70 SS396 Chevelle 4spd
70 SS396 Chevelle
70 BB 4spd Monte Carlo
70 SS454 Monte Carlo
71 SB 4spd Monte Carlo
71 SS454 Monte Carlo
71 Corvette LS-5 conv.
71 Corvette LT-1 conv.
71 Corvette LS-6 coupe
72 Monte Carlo
72 Monte Carlo Custom
72 442 W-30 clone
76 Trans Am SE 455 4 spd
85 Mustang GT Conv.
86 Grand National
02 SS conv.
Old 09-21-2007, 02:52 AM
DaveC68's Avatar
pic3
Dave C.
68 SS396 Camaro
70 340 Dart Swinger
70 SS396 Chevelle
72 Monte Carlo
72 442 W-30 clone
85 Mustang GT Conv.
86 Grand National
02 SS conv.
Old 09-21-2007, 02:53 AM
DaveC68's Avatar
pic4
Dave C.
68 SS396 Camaro
70 340 Dart Swinger
70 SS396 Chevelle
72 Monte Carlo
72 442 W-30 clone
85 Mustang GT Conv.
86 Grand National
02 SS conv.
Old 09-21-2007, 04:00 AM
Rixls6 Rixls6 is offline
I don't get it. If your XF tank is for an automatic, maybe someone put the trans cooler into it later.
The other guys are showing an XF tank as being original to an LS6 4-speed car, which wouldn't have a trans cooler in it.
Rick
Don't text and drive.
Old 09-21-2007, 04:06 AM
DaveC68's Avatar
Don't know
I only saw mention of XJ and IF
mine is XF
Dave C.
68 SS396 Camaro
70 340 Dart Swinger
70 SS396 Chevelle
72 Monte Carlo
72 442 W-30 clone
85 Mustang GT Conv.
86 Grand National
02 SS conv.
Old 09-21-2007, 05:26 AM
Rixls6
You're getting a lil backwards.Re-read the posts again,and you'll see it makes sense what the others have submitted.
X J is a Manual trans application,and X F is a TH400 application.
When any 1970 LS6 Chevelle was special ordered with the 4:10 posi upgrade,that canceled it's standard Big Block 3 core radiator,& it came instead with the larger capacity Big Block 4 core radiator.Which could have been either the PA manual prefix,consisting of the I F driver side tank,and X J Pass. side tank,or the PD TH400 prefix,which consisted of the I F driver side tank,and X F pass.side tank.
Understand that these two radiators were used as the Big Block Heavy Duty cooling radiators on the 1970 LS-6 Chevelle/Elcamino,but not exclusive to the them,as they also came as standard equipment on the 1970 L-34 & LS-5 Chevelle/Elcamino when equipped with optional Air Conditioning,or if just RPO KO-1 H.D cooling was ordered on them and that would include the 1970 L-78 Chevelle/Elcamino too.
In 1971,the PA & PD radiators were also available on all the BB Chevelle/Elcaminos under the similar circumstances mentioned above.
I believe your C I Passenger side tank was used on the 1972-74 GM A-bodies.
Old 09-21-2007, 04:25 PM
OOPS,
My bad. I was mixing up the XJ and XF.
Thanks for straightening that out.
Rick
Old 09-21-2007, 06:38 PM
DaveC68's Avatar
Rick,
If I understand correctly, the XF I have would be correct for my 71 SS454 A/T Monte with air?
I guess I'll be hanging onto it.
thanks for the info.
Dave C.
68 SS396 Camaro
70 340 Dart Swinger
70 SS396 Chevelle
72 Monte Carlo
72 442 W-30 clone
85 Mustang GT Conv.
86 Grand National
02 SS conv.
Old 09-21-2007, 06:54 PM
That's right DaveC.
Your 71 Monte Carlo LS-5/TH400 A/C equipped used that (4 core) P/S tank,along with the 3 core D/S tank denoted as I A,and the overall prefix tag BR.That was the Heaviest Duty radiator available for that particular vehicle.
That radiator was very popular among 1969-71 Chevrolet A & G bodies,part #3019205.
Old 09-21-2007, 09:19 PM
Rainer Rainer is offline
Rixls6
Rick - How does option VO1 heavy duty radiator fit into the mix? I have a 70 BB 4-speed car with that option. The build sheet lists a BQ radiator, and I have the original radiator with intact tanks and tag which indicate IA and XJ tanks.
1969 Chevelle SS396 L78 M22 4:10 Tuxedo Black
1970 LS3 Malibu 400 BB convertible
1970 LS3 Malibu 400 BB coupe
1970 Chevelle 300 series LS3 400 BB coupe, special order Monaco Orange
1970 Chevelle Concours Estate LS3 400 BB wagon
1970 Chevelle SS396 L78 M21 3:55 Tuxedo Black
The Following User Says Thank You to Rainer For This Useful Post:
RobR (05-20-2017)
