Old 09-02-2007, 12:14 AM
Default Re: 69 COPO Camaro Coil Spring.......code #'s ????????
Ride height with YP front springs.
Paul
Paul,
That ride height is sweet - and perfect!
Now I'm confused though. You mentioned YP springs on this
car, then you mentioned L/89 heads later..... Did I miss
something? Does this Camaro have iron, or aluminum heads?
And what about those NOS springs? Are they in this car now?
Nuch
Old 09-02-2007, 12:29 AM
You know, this issue has been debated numerous times here.
I looked at that front coil spring calculator last year,
but it seemed that there were so many variables to consider.
Does anyone here know, or have a reference chart regarding
all the front coil springs that were made for the '69 Camaro?
Do any members here have original springs that they
can use to verify tag codes?
I would assume that for big block, there are the determining
factors:
1 - L/35 and L/35
2 - Muncie or THM400
3 - L/78 or L/89
4 - A/C ( L/34 & L/35 only )
5 - 3 or 4-core radiator
6 - hardtop or convertible
As all BB Camaro's had SMOG and cast iron exhaust manifolds,
that can't be a factor. Nor can power brakes as that was
mandated. Would P/S add significant weight to require a
different spring pressure?
Can springs be clipped to reduce the ride height to a "desired"
height? If so, is there a formula ( other than try-it )?
Lastly, what exactly is the proper ride height? Paul's
Blue SS looks perfect to me. Got a ride height for us Paul?
Nuch
Old 09-02-2007, 12:40 AM
One more thought for the moderators. Perhaps we should start
a "sticky thread" for front coil springs. It sure would be
helpful to know what others owners have used for their
particular applications, and where they got their particular
springs.
Can unsprung height be used as a determining factor for used
springs? I know that when I source new springs for a particular
manufacturing project, unsprung height is a factor. Any thoughts
Nuch
Old 09-02-2007, 09:37 AM
Here is a shot of the car with L-89 Aluminum heads and NOS YM code front springs. The car was an original L-78, I added the Aluminum heads to save some weight. Last November, I sold the car due to a Divorce in November to a member on this site. To me, it looked perfect.
Paul
Old 09-02-2007, 10:07 AM
Paul, I am still interetsed in buying/trading for your YP springs......I just need more confidence these would be correct for MY "COPO" situation......versus another code lettered spring....
I suppose I will call Eaton Detroit, Ricks or "somebody" soon and ask for advice???????????
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 09-19-2007, 10:46 PM
still "reaching out" looking for knowledgeable specific info for correct front coil spring to replicate original on my COPO (L-72) clone with M-40..........
Thanks
Chuck Sharin
[email protected]
Old 09-20-2007, 12:32 AM
Chuck,
Check out the CRG forum as a very similar thread is there.
CRG thread
Nuch
Old 09-20-2007, 01:12 AM
THANKS very much......I have had conversations with sales mgr at Rick's and Eaton. I will add my comments....
I really need to hear from shops/users such as Brian, Larry C to find out WHAT to order , WHAT works............
Chuck Sharin
[email protected]
