Old 08-03-2007, 06:06 AM
Default Re: SuperSnake video
Carroll got it up to 170mph on the Goodyear test track and the car has 4:11 gears....how many rpm was that thing turnin'? Got any idea Charley?
Howard
Old 08-03-2007, 07:58 AM
He averaged 142 mph for 500 miles. The Lemans engine is built to run at 7K rpm for 24 hours but I have no idea on what rpm it takes to hit 170. Maybe different gears for the test ? I really like how the narrator calls it a specially prepared 650 hp GT500.
Old 08-03-2007, 04:54 PM
flyingn's Avatar
flyingn flyingn is offline
hard to believe. Thats a lot of air to push to get to 7000 rpm at speed.. Besides it would take a lot more then 7k rpm with a 4.11 geared car to reach 170..
Old 08-03-2007, 06:48 PM
I only know Carroll Shelby by reputation but I would say its fair to think that a racer with the press all to himself would "push the envelope", "tweak the rules" or whatever you like to call it. A gear change would be likely!
Does the car have a standard "Rug-S" toplaoder or something special? Besides the headers is the engine different than the 2 other factory 427 cars?
Don't forget to post the clip Peter did on the car as well. It helps explain the significance of the car
Howard
Old 08-04-2007, 06:37 AM
Charley...let me know what the rpms are at 60 mph in 4th gear and I'll figure out the rpm for 170 mph speed...
Old 08-04-2007, 07:18 AM
No need to tweak the rules or push the envelope if you are just doing a tire test. I think the test was planned to go 125 mph for 500 miles so common sense would call for a set of highway gears. Next time out I will check rpm at 60. Feels like 410 gears now though.
Old 08-04-2007, 07:35 AM
VintageMusclecar's Avatar
Well, I'm not Charley, but I can answer that question...
Not knowing the actual height of the tires in question, I took a WAG and plugged 26" into the equation.
In order to run 170 MPH with a 26" tire and 4.11 gears, the engine would have to turn a little over 9,000 rpm, assuming a 1-1 final drive ratio and not taking into account any tire growth at speed.
*edit* using a 28" tire, it would take a little over 8300 rpm, FWIW.
That's wingin' it pretty hard to say the least.
Eric
(p.s. The formula is MPH X Gear Ratio X 336 [constant] / tire height.)
Old 08-04-2007, 07:49 AM
TN2Lane TN2Lane is offline
Very cool video
I noticed Shelby climbs out through the drivers window at the end of the test. Necessary, or just force of habit?
Old 08-04-2007, 05:44 PM
That is AJ Foyt climbing out. At the beginning of the video it starts showing AJ doing a earlier Thunderbolt tire test. They have mixed the two.
Old 08-04-2007, 08:33 PM
47Hammer's Avatar
47Hammer 47Hammer is offline
Cool car, Great video.
